It appears to be a custom part for an APC UPS.
"Smart UPS 620 (SU620INET) No. NS9424340482"
See this discussion:
http://www.apc.ru/support/forum.html?idq=4850
http://translate.google.com/transla...c.ru/support/forum.html?idq=4850&namet=&idtn=
The OP has correlated the pinout of the DB9M serial connector to the
pinout of the IC.
Contact pin DB9M - pinU4:
pin1 - pin15 SDI;
pin2 - pin4 SDD; <----- should this be SDO ?
pin3 - pin 5 ONBAT NO;
pin4, 9GND - pin7, 8 GND;
pin5 - pin9 LOBAT NO;
pin6 - pin6 ONBAT NO;
pin7 - pin13 REMOT IN;
pin8 - svoboden (= free, not connected)
Here is a raw translation:
Update: Maybe not in the prog business? Smart ups 620 (SU620INET) ?
NS9424340482. Purchased without the signal cable. Found and soldered
circuit cable AP940 0024C: UPS / 1 - PC/3TxD; UPS / 2 - PC/2RxD; UPS /
9 - PC/5GND; PC/1DCD-PC/4DTR; PC/7RTS-PC/8CTS (link) APC PowerChute
Business Edition Agent 8.0. WinXPSP2. UPS operates, but to change the
network settings can not, because when you install Agent 8.0 compyuter
not "see" UPS and the "requests" to connect the cable. Opened the UPS.
Scheme corresponds Smart UPS SC620INET chassis 640-0232N. There at the
entrance to chip U4 360-2002B (dip16). Contact pin DB9M - pinU4:
pin1-pin15 SDI; pin2 - pin4 SDD; pin3 - pin 5 ONBAT NO; pin4,
9GND-pin7, 8 GND; pin5 - pin9 LOBAT NO; pin6 - pin6 ONBAT NO;
pin7-pin13 REMOT IN; pin8-free. Soldered the other cable-pinCOM -
pinUPS :2 --- 1 3 --- 2 7 --- 7 --- 5 4.9; Result - sompyuter still
can not see UPS!? I can not correlate the findings indicate chip U4
360-2002B symbols and signals a COM port. MAY ADDITIONALLY to
PowerChute Business Edition Agent 8.0. WinXP should install DRIVER
Smart UPS SC620INET chassis 640-0232N (G), if it exists? Thank you for
your attention.
- Franc Zabkar
