cannot find datasheet 6HUI07501833 - BC004 busch charger chip
First I have a very limited knowledge in electronic,
There is a chip on my bosch BC004 charger, the charger is defective and I will check every component.
I cannot find any datasheet or any info for a chip that is on the board. I tried the ST web site, Google, bing... nothing with 2 days of research. I am always ending up on a chinese web site with crappy links.
the chip is a ST
First line : 6HUI07501833
Second line: GK4520MC
thanks for the help
Michel
Picture will not help
Thanks for your reply CocaCola but there was some paint trace and some kind of varnish over the chip I had to scrape it off, it is very difficult to see the numbers I had to use a good magnifier and a flash light to see the numbers. But the numbers I gave are the right numbers.. if you think a picture is needed I can provide the photo.
Yes, pictures would help... We have no idea if this is a 3 pin device or a 100 pin device, a capacitor or an IC...
Chances are real good that it's a proprietary part or renumbered part as the only reference online is for hard to get or obsolete parts resources... You might have to navigate an obsolete and hard to get site and simply order a replacement or salvage one out of another good or broken unit, this isn't an uncommon practice for hard to find parts...
Well sadly at 16 pins and with no identification to be found, I'm going to place my money on it being a proprietary logic chip or at best an over the counter logic chip that has been rebranned... Sadly in both cases unless the manufacture clues you into what it does and what it's for you are pretty much out of luck... The good thing is that several of the obsolete vendors I saw listed the device as a DIP 16 and that is in fact what it is, so they are likely the correct chip, probably time to get a RFQ if you think it's defunct...
What is a RFQ
What is a RFQ ? I think that I will have to buy a replacement battery charger at 70$
this is such a waste of money:mad:
thanks anyway for you time is is verry kind of you.
