I just got this Trifield Broadband Meter in the mail today and when I turned it on the Magnetic (0 - 3) and the (0 - 100) ranges it moved to 3 milligauss, and as I moved around the room it slowly turned 3 1/2 to 5 milligauss to 2 milligauss and then back to 3 milligauss which is the standard reading for the room.
While the meter is on either one of these Magnetic (0 - 3 & 0 - 100) ranges, is it uncommon for it to read 3 milligauss or higher or should it be below this typically? Also shouldn't it read pretty much the same every time in the same location, because every time I check the room in the same location that I previously got a 3 milligausss or a 2 1/2 milligausss reading I get a 5 or 4 milligauss reading. Is this normal? (The batteries are brand new and in working order/strength.)
Here is the Trifield Broadband Meter.
http://www.trifield.com/content/trifield-broadband-meter/
Thank you for your help.
