Can one "overclock" a CRT monitor's video input bandwidth? Need slightly higher refresh rate than m
Phil Weldon
Could have fooled me. I would have guessed that 'amateur, computer based
video editing and production' required displays of some sort, and being
amateur, that squeezing as much performance out of less expensive equipment
and that this thread would be on topic for the Usenet newsgroup
rec.video.desktop .
Phil Weldon
| Gentlemen,
| This discussion was NEVER even remotely on-topic for the
| rec.video.desktop newsgroup (which is about television editing)
| And it has gone far afield from even the original inappropriate topic.
| PLEASE remove rec.video.desktop from further postings.
| Keep Usenet usenet discussions in their appropriate newsgroups
| for everyone's benefit.
| Thank you very much.
Michael Kennedy
Gentlemen,
Well this topic "Was" dead 3 days ago untill you posted to it again..
How is it not relevant to rec.video.desktop.. are there no technical
discussions over there about monitors?
- Mike
What I love about usenet... no stupid Moderators..
J. Clarke
Michael said:
Gentlemen,
There are but the monitor issue with desktop video as with digital
photography is calibration, not bandwidth. The best place to ask such a
question would probably be comp.sys.ibm.pc.hardware.video.
Richard Crowley
"Phil Weldon" wrote ...
'amateur, computer based video editing and production'
It requires mains power also. But that doesn't make
it an appropriate place to dicuss house wiring.
Richard Crowley
Gentlemen,
topic.
No. Not this kind of discussion. Televiaion (NTSC,
PAL, etc.) is actually much *lower* bandwidth than
most computer monitors.
K
Ken Moiarty
If rec.video.desktop is only for matters to do with television editing,
seems to me a more appropriate name for this group (e.g.
rec.video.tv-editing) would have gone a long way towards preventing many an
inadvertent off-topic post.
Ken
Richard Crowley
an inadvertent off-topic post.
Agreed. But it does make sense in the context of the rec.video
hirearchy. And besides, we are stuck with it for better or worse.
The name was decided before any of us got here.
Phil Weldon
Would you have the rec.video.desktop newsgroup exclude discussion of digital
cameras?
How about DGI?
Keep in mind that with a digital train, NTSC or PAL NEVER exist except for
possible display on an analog NTSC or PAL monitor.
And the monitors used for the kind of editing discussed in the newsgroup are
NEVER NTSC or PAL.
And NTSC, PAL, SECAM, and variants are being marginalized with the advent of
High Definition TV.
Phil Weldon
Richard Crowley
"Phil Weldon" wrote...
discussion of digital cameras?
Discussion of cameras used for production would more
properly go in rec.video.production. Cameras as used
for capture/record devices in NLE systems would seem
to be appropriate for r.v.d But that would be apparent to
anyone who hung around either newsgroup for more than
a couple of days. But, in reality the two newsgroups are
so similar that discussions frequently slop over into the
other newsgroup and many of us read them interchangably.
How about DGI?
Do you mean the Direccion General de Inteligencia, the
Cuban secret police? http://en.wikipedia.org/wiki/DGI
Cuba uses NTSC (which I found surprising, I would have
assumed SECAM as the rest of the Communist Bloc)
exist except for possible display on an analog NTSC or PAL
monitor.
I guess that depends on how you define "NTSC" and "PAL".
Most people define it as the dimension of the frame in pixels,
and the frame rate (and the interlaced fields). You can be sure
that people who try to mix NTSC and PAL very quickly discover
that they are quite real, whether in analog or in digital form.
Except for the handful of people on the bleeding edge who have
HDV, etc. camcorders, every other camera represented here is
either NTSC or PAL. Regardless of whether it is analog or digital.
It has been that way since first NTSC (and then PAL) camera
and continues to this day, unabated.
NTSC and PAL are not even processed the same in digital
form. For example, in DV (the most widely-used digital video
codec), NTSC is sampled 4:1:1 (Y,U,V) while PAL is
sampled 4:2:0 http://en.wikipedia.org/wiki/4:2:0
newsgroup are NEVER NTSC or PAL.
Actually, people who are motivated to do quality video editing
never use computer monitors for qualitative evaluation of TV
pictures. You just cannot display a proper television picture on
a computer monitor. Mainly because of the very great difference
in gamma transfer curve, and also because of differences in
colorimetry. A good television monitor likely costs more than
your whole computer system (or maybe 2x or 3x more).
with the advent of High Definition TV.
If you post that again in ~5 years, you might be right.
Phil Weldon
Then I take it that in your view input format isn't a proper discussion for
rec.video.desktop?
I guess you don't watch movies, right?
DGI: Digital Graphics/Imaging
What Communist Bloc?
SECAM is French, though SECAM content is produced in PAL, and only at the
transmitter converted to SECAM by a very simple process.
NTSC and PAL and SECAM are defined as SMPTE ( <http://www.smpte.org> )
defines them.
All are standards for encoding color video signals. Digital video signal
encoding is completely different (MPEG2 for example.)
Pixels are not part of NTSC, PAL, or SECAM.
Well, there you go again, posting about video cameras!
And you are wrong about digital video recording; the encoding is neither
NTSC, PAL nor SECAM.
What makes you think that the signal from the sensors of a digital camcorder
is encoded in NTSC or PAL before recording? If you have a COMPOSITE, analog
signal output it may be NTSC or PAL, but not if the output is a digital
signal.
People who are motivated to do quality video editing use digital signals,
and produce a digital recording.
Which brings up the question, what do you mean by a good televison monitor?
Certainly in editing on a non-linear system a NTSC or PAL analog monitor is
not appropriate. Of course you can display a proper television picture on a
computer monitor. You are completely wrong about the 'gamma transfer curve'
as the display adapter in a computer can set whatever gamma curves are
desired (good computer monitors come with color rendition files.)
The real use of a 'good' television monitor is to determine quickly the time
stability of the content, blanking, and framing. More elaborate,
quantitative instruments are required to do any real evaluation (waveform
monitor and vectorscope for analog NTSC/PAL, more elaborate instrumentation
for digital signals - see
<http://www.tektronix.com/Measuremen...nt/App_Notes/25_7049/eng/&FrameSet=television>
You are refering to my statement: "And NTSC, PAL, SECAM, and variants are
being marginalized with the advent of High Definition TV."
My statement is correct - 'are being marginalized' means 'are in the process
of marginalization.' One example is the imminent demise of analog TV
broadcast in the USA.
Finally, I don't know if your assertions are typical of rec.video.desktop,
but if they are, I'd say a little cross-fertilization is a Good Thing.
alt.com.hardware.overclocking, for one, includes some broadly knowledgeable
contributors.
Phil Weldon
| > How about DGI?
| > monitor.
Martin Heffels
Heck no. Before 1959 there was a lot of American interest in Cuba. So NTSC
was introduced before El Presidente took control with his July 26th
Movement.
Quite real, and quite incompatible :-(
Market protection?
I think that is only half the truth. Printers have very high-quality
computer-monitors to check their work on. And those are very expensive as
well.
That's what they are saying already since ages. Seeing is believing :)
cheers
-martin-
Never be afraid to try something new.
Remember that a lone amateur built the Ark.
A large group of professionals built the Titanic.
Inviato da X-Privat.Org - Registrazione gratuita http://www.x-privat.org/join.php
Jukka Aho
NTSC and PAL and SECAM are defined as SMPTE (<http://www.smpte.org>
) defines them.
ITU-R BT.470 would be more authoritative at least for PAL and SECAM than
anything SMPTE says.
But let me help: what Richard means is that, in common everyday speech
people tend to call 625-line / 50 Hz formats (and their digital
equivalents, such as 720×576) "PAL" and 525-line / 59.94 Hz formats (and
their digital equivalents, such as 720×480) "NTSC" - regardless of
whether the colors are actually encoded as PAL or NTSC.
That's inaccurate, sloppy usage, of course (and there are some
PAL-N/PAL-M countries where this implied "PAL = 625/50/576, NTSC =
525/59.94/480" relationship doesn't even hold true), but those are still
the name tags that people most commonly attach to these formats. Why?
Because "PAL" and "NTSC" are usually more convenient and more compact
for this kind of use than the other available alternatives. The message
usually gets through by using "PAL" or "NTSC" even though the
terminology is a bit off. You may not like it and I don't like it
either, but it's impossible to get people stop using these terms
sloppily. (Hardware manufacturers and software houses use them in a
sloppy way, too.)
camcorder is encoded in NTSC or PAL before recording? If you have a
COMPOSITE, analog signal output it may be NTSC or PAL, but not if the
output is a digital signal.
He doesn't think that. He just uses the acronyms "PAL" and "NTSC" as
name tags for 625/50 and 525/59.94 Hz formats, as described above.
signals, and produce a digital recording.
Yes, but up until the last couple of years they have monitored the
results on a professional-grade, color-calibrated, 15 kHz analog
CRT-based video monitor - such as one of these:
<http://www.expandore.com/product/Sony/Monitor/ind
ex.htm#PROFESSIONAL%20VIDEO%20MONITORS>
Professional production has moved or is in the process of moving to HD,
and people are buying flat panels instead of CRT-based sets - but we
were not discussing HD here.
As long as the majority of tv sets are still SD and CRT-based, and as
long as we're still shooting and processing standard-definition
interlaced video, professional-grade CRT-based 15 kHz video monitor is
the way to go. Flat panels can't show interlaced signals the way
CRT-based sets do (simply because panels don't update the picture by
scanning), and their color rendition is different. Things are about to
change in the next couple of years as more and more people are replacing
their CRT-based sets with TFT panels and as we're starting to get
HD-based consumer video formats, but we're not there yet.
monitor? Certainly in editing on a non-linear system a NTSC or PAL
analog monitor is not appropriate.
What do you mean by "analog" monitor? For example, all CRT-based
VGA-monitors are "analog" by definition.
The pro-grade 15 kHz analog video monitors used for video editing
typically have component (Y'PbPr) or RGB inputs, or, in some cases, SDI.
As long as analog PAL, SECAM, and NTSC transmissions are still on air
(or on the cable), people should also check that their video stays
within the legal broadcast levels. This can be done without visual aids,
but it still doesn't hurt to check how the pictures will actually look
when encoded to true composite PAL or NTSC. The old analog systems have
their limitations with allowed color saturation or workable adjacent
colors. These sort of checks and practices will of course become
obsolete when the analog transmissions are turned off for good, but
they're not quite obsolete yet.
computer monitor.
For starters, many TFT panels have severe issues with their black level
(the backlight is shining through) and a limited color bit depth, which
causes banding on color ranges. Then there's the viewing angle issue:
colors will look different depending on the angle from which you look at
them. Some monitors will also clip black and white levels. Then you have
the problem of not being able to assess whatever flickery problems
interlaced scanning might cause to certain types of pictures when
displayed on a regular CRT-based tv set. The list goes on and on; gamma
is but one of the problems.
Of course, many many many video processing programs don't even _allow_
you to adjust anything to a given specification, or two programs may
display the same video with different colors/luminance range (the
16...235 vs. 0...255 luminance range issue.) Regular color calibration
generally doesn't even apply to video overlays. What is more, when
watching your interlaced videos on a computer screen, you often get to
see only half of the motion since many video players (and NLE apps with
preview functions) don't even _try_ to display the video on
field-by-field basis. If you don't monitor on a CRT-based interlaced
video monitor, you might have something as trivial as the field order
wrong without realizing it, which will make the video look horrible when
it is played back on a regular CRT-based tv set.
alt.com.hardware.overclocking, [...]
Followups have been set to go back to rec.video.desktop only.
Phil Weldon
'Jukka Aho' wrote, in part:
_____
Thanks for explaining Richard's explanations.
Just two among many quibbles:
RBG is neither fish nor fowl nor NTSC nor PAL nor SECAM, it is unencoded.
Since nonlinear video editing is done on digital systems (else it could not
be nonlinear), it is done with monitors that display the digital, unencoded
signals, sometimes with multiple windows. The 'professional' encoded video
monitor is a valuable quality check, but not sufficient for engineering
purposes.
Phil Weldon
| > ) defines them.
| sloppy way, too.)
| > computer monitor.
| znark
Michael Kennedy
You know we have all kinds of off topic discussions over here at
sci.electroincs.repair
I once asked about the best way to go about cutting glass and all sorts of
peple jumped in with suggestions.. I didn't get any flames for posting off
topic.. Allthough I do admit crossposting to 10 different newsgroups can be
a bit irritating.
You must be annoyed with this since you are probably using google groups and
this keeps poping up in the active older topics box or whatever it is
called.. If you use outlook instead you'd have to scroll way down to see
this topic since it sorts everything by the first date it was posted.
Just some thoughts..
- Mike
Richard Crowley
"Video" (nether analog nor video) does NOT EXIST
in a vacuum. Without a definition of sweep rates, phase
angles, etc. an analog video signal is just noise.
Without a defenition of the frame dimensions, rate,
color encoding, etc. digital video is just random
ones and zeroes.
(else it could not be nonlinear), it is done with monitors
that display the digital, unencoded signals, sometimes
engineering
Actually, the situation is quite the opposite. Traditional
shadow-mask color CRTs are the only industry-standard
monitors trusted enough to make qualitative evaluation of
television images.
For several years after Sony started selling pro-level trinitron
(stripe-mask) monitors, camera shaders would not use them
for their critical QC function because they artifically "sharpen"
the image (by virtue of the mechanical "comb filter" effect).
The shader is the central person responsible for the exposure,
color match, and focus of cameras in a multi-camera live
switched production. It is a critical function and the best
monitor in the house is used for it.
Have you ever seen a calibrated Sony BVP or an Ikegami
monitor displaying a pristine NTSC or PAL video image?
No computer monitor can reproduce that.
There are some LCD monitors that are starting to make
inroads on the traditional CRT market, but they are still
unbelievably expensive. Perhaps someone just returning
from NAB can fill us in on the state of the art.
Richard Crowley
Perhaps you mean "CGI" ?
http://en.wikipedia.org/wiki/Computer-generated_imagery
Google doesn't seem to know your definition of "DGI".
http://en.wikipedia.org/wiki/Communist_bloc
It was in all the papers.
PAL, and only at the transmitter converted to SECAM by a
And SECAM was also selected by the USSR and propogated
across the communist bloc specifically to implement another
degree of state-controlled flow of information (to prevent
the populous from accidentally receiving any non-approved
propaganda).
( <http://www.smpte.org> ) defines them.
People on the right side of The Pond would take great
exception to the notion that SMPTE defines PAL (or
SECAM :) Perhaps you have your standards authorities
confused?
SMPTE is a US-based organization. My membership
certificate is in the other room. Furthermore, the NTSC
compatible color standard was defined by the "National
Television Standards Committee", not the by SMPTE.
Digital video signal encoding is completely different
(MPEG2 for example.) Pixels are not part of NTSC,
PAL, or SECAM.
Likely true in your theoretical world. Certainly not the
case in the real world.
A popular subject in r.v.d and r.v.p
encoding is neither NTSC, PAL nor SECAM.
You are so far from the kind of digital video that we deal
with every day that I have no clue where you are coming
from. I am unable to even respond to that very remarkable
statement.
Try reading an explanation of one popular form of digital
video (DV): http://en.wikipedia.org/wiki/Dv Note that
in nearly every paragraph, the differences in DV encoding
for NTSV vs PAL are contrasted.
a digital camcorder is encoded in NTSC or PAL before
recording?
If you read carefully, you will not that I did not say that.
I said that the video is encoded into (as a real-world
example) DV-NTSC or DV-PAL or MPEG 1 - 4 with
NTSC or PAL dimensions and frame-rates.
If you have a COMPOSITE, analog signal output it may
be NTSC or PAL, but not if the output is a digital signal.
And yet the most popular digital video codecs on this planet
(DV and SDI) are defined in either NTSC or PAL varieties.
They are not even recoverable without the knowledge of
whether they were encoded as NTSC or PAL.
digital signals, and produce a digital recording.
Which are QC checked on a real television (NTSC or PAL)
monitor, NOT on a computer display.
A Sony BVP or Ikegami monitor and their ilk. Have you
ever seen pristine NTSC or PAL video on a calibrated
broadcast-quality color television picture monitor?
or PAL analog monitor is not appropriate.
You seem to have no experience editing video, linear
or non-linear.
on a computer monitor. You are completely wrong
about the 'gamma transfer curve' as the display adapter
rendition files.)
You are entitled to your view of the world. People who
do quality video for a living do not share that view.
determine quickly the time stability of the content,
blanking, and framing. More elaborate, quantitative
(waveform monitor and vectorscope for analog
You seem to be aware of only the technology part of
making good video, and completely ignoring the "art".
No amount of technology can substitute for an
experienced camera shader with a good eye and a
calibrated picture monitor.
Phil Weldon
Let us keep this short.
Now you are moving your 'arguments' from 'amateur' non-linear editing to
broadcast studio production.
I assure you broadcast studio production is not done the way you present.
I don't agree with your view of 'video', nor your view of technical
evaluation of video signals.
There are timing standards for video signals, and then there are color
encoding standards, and then there are digital encoding standards for
compression.
NTSC and PAL severely limit the luminance bandwidth of encoded signals
(SECAM is nearly identical to PAL.) Broadcast regulations in the various
countries limit the bandwidth for broadcast signal. This is NOT good for
image quality, but was a necessity. Trade-offs were made. In these color
encoding methods the blue channel is very restricted in resolution compared
to red, and especially to green. PAL and SECAM made the trade-off of
gaining spatial resolution at the expense of time resolution. That is why
PAL and SECAM have an annoying flicker, while NTSC has lower spatial
resolution and higher time resolution. In the era when these timing
trade-offs were made, choices were made for very simple reasons - 50 Hz
mains power in Europe and 60 Hz in the USA. Without color, no more exact
timing was necessary.
Yes, since 1980.
Phil Weldon
| ones and zeroes.
| > engineering
| television images.
Jukka Aho
unencoded.
Nothing was said in the above quoted block about RGB being "encoded", so
I'm not sure why you're bringing it up. But if you wish to discuss
"RGB", please specify what kind of application of "RGB" do you mean. RGB
can exist in both digital and analog forms, it can be full-range RGB or
not, there can be a "setup" or maybe there isn't, there is 15-bit RGB,
16-bit RGB and 24-bit RGB, analog RGB signals can be created with
tv-compatible timings or VGA-compatible timings, sometimes the RGB
data/signal has gamma on each component, sometimes it is treated as
linear, etc., etc. Saying something trivial like "RGB is unencoded" is
simple, but dealing with actual RGB data or analog RGB signals isn't
always so.
In any case, common digital video formats use YCbCr - not RGB - as their
native format for storing pixel data samples. (This is partly because
these formats are, in one way or the other, derivations of ITU-R BT.601,
and in big part because color subsampling allows packing video data in a
tighter space without losing too much of perceived quality.) When
dealing with digital video, it is usually YCbCr data you're processing.
RGB is only relevant in the way how it comes into play when that YCbCr
data is to be displayed on a computer monitor - when you're processing
the video and trying to monitor what you're doing - and, of course, when
you're importing computer-generated graphics assets to your video
project which usually involves an RGB -> YCbCr conversion. As described
in the previous message, not all video tools are very good at doing
these YCbCr -> RGB preview conversions in a way that would give you any
idea of the real colors on a computer monitor, and RGB -> YCbCr is yet
another kettle of fish.
could not be nonlinear), it is done with monitors that display the
digital, unencoded signals, sometimes with multiple windows.
As I hopefully managed to explain above, it's not that simple.
Displaying digital video on a computer screen involves conversions
between the RGB and YCbCr color spaces, black and white level, gamma,
etc. Many digital video tools don't even _try_ to do these conversions
in any way that would begin to faithfully emulate how the image will
look on a tv screen. (One of the many problems involved with assessing
digital video quality on a computer screen is that a CRT-based tv screen
typically has brighter whites than a computer screen - the electron gun
is driven with a higher voltage, even to the point of getting the
so-called "blooming effect".)
In another post you seemed to be questioning whether all this is at all
relevant to hobbyist-level home video editing. For all the reasons
discussed in this thread, many people (yours truly included!) prefer to
edit DV with their camcorder connected simultaneously to the PC (via
Firewire), and to a 15 kHz video monitor - or, in lower-end setups, to a
regular tv set - using the analog output terminals on the camcorder
(preferably s-video.) No tape is involved - the camcorder just acts as a
realtime DV data stream -> analog video converter.
This is usually a much better setup than trying to rely on the NLE app's
"monitor" windows only. Modern DV-aware NLE apps allow previewing and
scrubbing the timeline directly through the camera, and they even give
previews of the title and effects editors through DV, so you get to see
how the colors/gamma, interlacing, and overscan will actually work out
on a real tv screen, instead of just guessing.
The 'professional' encoded video monitor is a valuable quality
check, but not sufficient for engineering purposes.
Even a non-professional, non-calibrated domestic tv set will help in
judging certain important aspects of the image quality much better than
a computer monitor would. Fluid interlaced motion, field-related
problems, at least some rough understanding of the final colors and
brightness/gamma (including possible color clamping problems the codec
might have, and which don't necessarily show up on the computer screen
at all) - etc., etc.
NLE editing without a 15 kHz video monitor (or tv set) by your side is
much like editing blind - unless you're working on something that isn't
ever even _intended_ to be displayed on a regular tv set, such as
streaming web video.
"Followup-To" header corrected again.
Michael A. Terrell
ones and zeroes.
Gee, the RADAR guys would really disagree with your definition of
"Video".
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
