Hello!
I'm trying to make something useful out of this solar-powered outdoor night light, and I thought maybe turn it into a solar powered flash light, by using a bigger battery and a brighter LED. Could I just switch out the NiCad in the circuit for a NiMH, or do they charge differently?
The battery that it came with is a 350mAh NiCad, and it uses a very very simple charging circuit (a single 4 pin chip, a N5819 schottky diode, and resistor).
I think the diode is a blocking diode, to prevent the battery from discharging through the solar panel at night, but the chip doesn't appear to be a "battery charging" chip, it seems to be specifically designed for solar panels.
It appears there is also supposed to be a 470uH inductor in the circuit, but there isn't one in mine. Here's the info I could find on the chip, but it was in Chinese:
"Solar Lawn Light Controller ANA608-6
Product Overview:
Solar Lawn main use solar energy to work, when the day sunlight on the solar cell, the light energy into electrical energy stored in batteries, and then in the evening for the lawn by the battery LED (light emitting diode) to provide power supply."
"Current regulation Reference: inductance value can be changed by changing the size of the input current, the inductor current relationship with the input reference to the following table: Inductance 150uH 100uH 82uH 47uH input current (input voltage 1.30V) drive white LED 11-13mA 18-21mA 22 -25mA 29-34mA Driver yellow LED when 11-13mA 20-24mA 24-27mA 30-35mA"
Product Overview:
