I'd like to turn an LED on and off by controlling the CD (carrier
detect) line of an RS232 port. I understand that the RS232 port runs at
+15volts. If I calculate the current draw for the LED and put an
appropriate resistor in series will I have a good solution?
Or, do I need some sort of voltage regulator in line?
My goal is to also put an opticaldetector on another RS232 port so I
can send a signal between two computers on two different networks (that
can not be connected any other way).
Thank you!
John
Thank you!
John
