Platforms
Content
Best show the circuit.I'm designing a circuit that requires BC548, and the circuit is for amplification purpose. Can I replace it with 2N3906 and 2N3904?
Thanks for the informationHello,
Here is an extended list of semiconductor coding as @Hunter64 shortly explained:
https://www.qsl.net/yo5ofh/doc/transistor_codes.htm
Bertus
Thank you!! So BC548 can be replaced by 2N3904 but not 3906The 548, 3904 are general purpose NPN transistors. The 3906 is PNP.The first two can be inter changed.
I think the BC series are common across the pond and 2N are Europe. I could be wrong though.
EDIT: The 548 is 100mA, 30V. The 3904 is 200mA, 40V. So compatible within the specs.
Martin
Yes, that is correct.
I think that BC came before ADI think the BC prefix was initiated by Mullard.
That's simple enough to put them in backwards. Then it's correct.
