Hello to all who have answered, and "thank you",
I am going to try as best I can under the circumstances to describe what my request for help is for, which hopefully will possibly clear things up a bit.
First -- there are two sets of 3 series connected MOSFETs, a common resistive LOAD, and 2 more series connected MOSFETs between the two circuits "Ground" connection and 24 VDC "V+" connection.
These two "sets" of MOSFETs are positioned within a circuit that also includes a common LOAD to them both, and also a common full wave bridge rectifier topology common to both MOSFET sets.
Each complete MOSFET "set" is activated sequencially, at a specific frequency just under 65 kHz, controlled via the dual 12VDC, 50/50 duty cycle, square wave output signals from a 14528 Dual Adjustable Monostable signal generator. .
The reason for using MOSFETs connected in series in each "set" is to be able to control the direction of voltage movement through common circuitry to both MOSFET sets in an opposite / reverse direction in some areas such as is common in a full wave bridge rectifier.
The full wave bridge rectifier, in this case, is not diode based due to the voltage drops incurred, but are all N-Type MOSFETs, based on higher effeciency and controllable "on" / "off" times per MOSFET set separate from the input input frequency .
This circuitry is not for any type of voltage control, as the MOSFETs being used are 600 VDC / 30 Amp / TO220 MOSFETs and the circuit "V+ value is only 24 VDC.
Both series sets of MOSFETs sequentially supply voltage to the "common" resistive load, and the "routing" through the common sections of the circuitry is controlled on the "Ground" section by the three low side MOSFETs effectively wired in series, with the two high side MOSFETs, again effectively wired in series, completing the circuit.
Each of the two sets of series connected high side MOSFETs are driven by a NCP5104 driver, with both low and high side driven in unison.
I would post the schematic as requested here if the circuitry was under patent protection; but it is not as yet covered, so I cannot post it.
I realize that this makes the job of understanding that much harder, but my hands are tied at the moment and I hope that this is not a "game buster" for all of you.
I ask that you "center" specifically on my question / description and not leap to preconceived notions as to the circuitry purpose -- this will only make things more difficult.
I can tell you that the circuitry has worked when rectifier diodes were used, but their drawbacks have necessitated this design change to MOSFETs, mainly because this is a low voltage trial and when successfully completed, the V+ value will be raised to several hundreds of volts.
Because MOSFETs are not normally connected in series for "back and forth" voltage direction control in a common circuit -- I have come to you for help.
I will endeavor to do my best to describe the circuitry in question to you.
Thanks in advance for any more help you may offer.
