Jim Thompson
I read in sci.electronics.design that Fred Bloggs <[email protected]>
It's how I do it in practice. YMMV.
Same here. No j•omega until the end... much easier to be error-free.
...Jim Thompson
There was a really neat monograph in, I believe, Electro Technology (long
since out of publication) circa 1963 about performing impedance calculations
graphically using a straight edge, compass and protractor. It was brown and
brittle the last time I saw it and I can't seem to find it now (so what's
new) but one could solve reasonably complex problems rather simply and
without advanced math. Solutions even approached slide rule (what the hell
is that?) accuracy.
The impedance of the 25pF capacitor at 10MHz is 636 ohms (times -i).
This means that the parallel resistance of 50K is almost negligible.
The impedance of the 10 uH inductor at 10 MHz is 628 ohms (times i).
You are very near resonance at 10 MHz... as a result the combination of
the L and the C gives a near-zero impedance. The 33 ohm resistor then
dominates. So effectively at resonance (which is I assume why you're
asking about 10MHz) the stuff to the right of "A" is almost exactly like
a 33 ohm resistor to ground.
Does this help any?
Because the j way is messy on paper. Work out all the stuff with sL,
1/sc and R, then plug in the s=jw at the end.
Your circuit includes a capacitor and an inductor. To calculate the
impedance oof the whole circuit you have to recognise the fact that
the impedance of a circuit including reactive elements has to be
represented by a complex number
a+ib
where "i" is the square root of minus one.
The impedance of a capacitor at a particular frequency f Z(c)= -i/wC
where w is the frequency in radians per second, which is two pi times
the frequency in Hz, and c is the capacitance in farads.
The impedance of an inductor is similarly Z(L)= iwL
Complex impedances, so defined, can be added in series and in
parallel, just like simple real resistances.
"s" is just electrical engineers shorthand for iw or 2.i.pi.f.
Hope this helps. But I guess that what you really needed was a good
night's sleep.
Well I've had a peek at your link and one of my reference books and it
appears this Laplace stuff involves calculus. Algebra's one thing, but
I never got around to studying Leibnitz's little contribution to
science and don't plan to start now. So I guess I'm stuck with the
messy way!
Kevin Aylward said:
I think Newton made a "minor" contribution also ;-)
Tim Shoppa said:The impedance of the 25pF capacitor at 10MHz is 636 ohms (times -i).
Does this help any?
Tim.
Jim Thompson said:Actually I believe it was Heaviside who came up with the notational
trickiness using "S".
Paul Burridge said:Hi,
It's midnight here and I'm suffering from brain failure.
Can anyone come to my rescue and show me how to work out the impudence
of this circuit fragment? (I know, but everyone's brain's entitled to
not function once in a while and I'm getting my -js and +js all mixed
up). :-(
Sine wave input to left of 50R resistor (representing Rgen) at
frequency of 10Mhz.
Need to know total impedence from point A through to ground. Thanks.
<knackered>
50R 33R 10uH
___ A ___ ___
Sig ---------|___|---------|___|----------UUU--+
input |
25p | 50k'-'
GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
Paul Burridge said:Well I've had a peek at your link and one of my reference books and it
messy way!
"Windows [n.], A thirty-two bit extension and GUI shell to a sixteen bit patch
to an eight bit operating system originally coded for a four bit
microprocessor and produced by a two bit company."
If you do a lot of calculating, you might want to consider buying a
calculator that handles complex numbers. I have a HP48G, I have
buttons programmed for XL, XC and parallel with a single button press.
It makes the imedance of a bunch of caps+inductors no more difficult
to calculate than a bunch of resistors.
Baphomet said:From the "How quickly they forget" Department.............
Paul Burridge said:Yes it does, Tim, thanks. It's yet another way of looking at the
problem and I find it's invaluable to have as many different
perspectives as possible when trying to get to grips with something
like this. Some explanations on this thread have been rather
impenatrable, I'm afraid, but yours is not one of them! Thanks again.
Newton wasn't a Linux kind of person ...
Even though my answer probably wasn't even good to two decimal
places
Paul Burridge said:Yes. *Minor* being the operative word. In between odd bouts of
character assassination, plagarism and vote-rigging with the RS., to
mention some of his better qualities. Let's not waste valuable
bandwidth discussing that over-rated PoS, please!
Bill Sloman said:Newton invented it first, but Leibnitz published first, which is why
we use the notation invented by Leibnitz.
Had Newton published before Leibnitz, one might be able to talk about
his contribution (and it wouldn't have been minor), but as it was
Newton sat on the technique. Had he published it earlier, Hooke or
Wren (or perhaps both together - they were good friends and close
colleagues) would perhaps have been able to do do the maths required
to take the inverse square law (which they seem to have come up with
before Newton) and use it to explain Kepler's Laws of planetary motion
(derived from Tycho Brahe's observations). Had they done so, Newton
would now be much less famous.
Bill said:Your circuit includes a capacitor and an inductor. To calculate the
a+ib
