Platforms
Content
I would go for A since the feedback comes from the output.
The gain is determined by the feedback which comes from the circuit output, not from the op-amp output. The calculations you have shown deals with the voltage at the op-amp output which is of no concern, it will be greater than the circuit output voltage and will depend on the load.
No, no The feedback comes from the output so the output voltage will be controlled by R2 and R3 so long as the op-amp can drive it through R1.The voltage at the opamp output is of "no concern"??
I rather think, we have an active device (called opamp) which has a low-resistive voltage output and it is THIS output only which provides voltage feedback!
The only difference to the classical non-inverting circuit is that we do not further process the ouput voltage at the opamp output (for which reason ever) but the voltage between R1 and R2 (simple voltage division).
Referenced to this node (between R1 and R2) the gain is as given by ramussons (post#7).
And - yes, this output voltage (and the gain) will depend on a possible load resistor; however, thius was not part of the question.
Referring to the original schematic, the opamp voltage gain from pin 3 to pin 6 is as in equation A, with a series feedback resistance of (R1+R2). Pin 6 is a zero-ohm point at voltage (Vin times the gain). Pin 3 is a zero-ohm point at voltage Vin, driven there by the opamp's closed loop. So R1 and R2 form a voltage divider between two zero-ohm points of two signals with identical frequency and phase, but different amplitudes. Enter Ohm's Law.
All of that assumes a perfect opamp and an infinite impedance load at Vout.
ak
Thank you Harald.
With 1V in, the voltage at the junction of R2,R3 will be 1V.
The output will be 2V.
U1 out will be 3V wih no load.
Thank you Harald.
Yes - of course, this is correct.
But this result was given in general form in post#7 already:
A = [1 + ( (R1 + R2) / R3)] * (R2+R3)/(R1+R2+R3)
Harald:
How can you say that R1 has "no influence"?
R1 has no influence on Vout as long as the opamp can drive enough current, see post #10.
This kind of circuit is sometimes used with capacitive loads. Most opamps are limited in their capability to drive capacitive loads. The resistor R1 helps to stabilize the amplifier in that case while the feedback via R2/R3 from Vout is required to set the gain correctly.
As much as I deSPICE the use of a simulator when a thoretical calculation can give the result, I follow @duke37 's request:
As expected gain is 2 (1+R2/R3).
Changing R1 has a rather small influence on gain (in the 1 % range, depending on how much R1 is changed). This is a frequency dependend effect which at e.g. 10 Hz signal frequency is almost not visible. Possibly the opamp model and some implicit parasitic capacitances in the simulation cause this effect.
In real life the real parasitics and the real frequency response of the opamp will have even more impact.
