Q
qu1nn
Hello
I am under the impression that if you wanted to protect a sensitive
electronic device from external coupling (aka nearby cables near a
switch or a sensitive cable near a noisier one) that it would be best
to use shielded twisted pair with 100 shielding. Generally when you
have 100% shielding it would be a foil with a bleeder cable strands.
However if you get a cable with braids you only get 90% coverage.
So if one is to ignore the ENDS of the cable and you are only looking
at protection from nearby em fields would it not make more sense for
100% shielding? or is it that the foil shield does not really "perform
as well"?
Thank you for your time
Qu1nn
as well"?
Qu1nn
