Cable For My Waveform Generator?
K
Ken Williams
I just got a arbitrary waveform generator.
it didn't come with a cable. How do plug the signal into my circuit? Is
there a special coax cable I can use/buy? Can I just use the same type
of leads/cable that I use with my oscilloscope?
Any direction would be great. Can I get an antenna so I can directly
send out AM/FM waves into the air? (it supports AM/FM Modulation).
Thanks.
1
1PW
The specs for the generator should say what the output impedance is.
Match the output impedance with a like cable impedance. If you tell us
the make and model of the generator, we can help more.
This might make you *very* unpopular. On either side of the
international border.
It also might earn you some unannounced visits and confiscation by
government officials.
Pete
K
Ken Williams
I have this:
http://www.tequipment.net/RigolDG2041A.html
So I have to buy a cable with an impedance that matches what the
generator is using then correct?
K
Ken Williams
Sjouke said:
The site links to a pdf document, at page 6-6 input and output
impedances are specified I spotted 5K in, 50 ohms out.
Thanks, so now I need cable that is 50 ohms too.
1
1PW
I have this:
Hello Ken:
At $1,500USD, your Rigol function generator is very impressive. Its
output impedance *is* 50 ohms at the front panel output BNC female
connector, and is so marked at the right of the jack as you can see.
Yes, you would want a 50 ohm coaxial cable, terminated in a male BNC
connector on at least the generator's end. The cable itself is
typically RG-58/U, or from its family.
Please use your generator wisely.
Pete
K
Ken Williams
1PW said:
On 03/26/2009 09:51 PM, Ken Williams sent:
Hello Ken:
I just noticed that, it says 50 ohms right on the front. It also has a
42Vpk on it. Does that mean the max voltage coming out of the coax will
never be over 42 volts peak to peak?
