I'm working on a Western Rivers Predation game caller. Bought it second hand from ebay and worked the first time. Then wouldn't turn on, charge nothing. Bought a new battery pack 8.4v 1300mah and it worked on an outing then sat for about 6 months, then nothing. I disassembled it to find black wire to the battery pack was disconnected from the board, I soldered that back along with the charging port as that seemed loose. Then it worked with the new and old battery, also charged from the charging port. I then replaced the ends on the original battery 8.4v 400ma and everything worked for two outings. Left it out in the truck last night, now nothing, won't turn on charge nothing. Just get a burning smell when I plug in the charger!
I tested the charger that I thought was the original ( Csec AC adaptor 12vdc 400mA) and it charged at about 12volts then 25 volts back and forth and got really HOT.
The one I'm using now is a 12vdc 1A that stays constant and seems to react with the unit as it says charge complete. The other one doesn't now. Anyone have a solution???
