K
K. Jones
Hello.
I've recently purchased a one acre lot that I intend to build a home on,
starting in about a year. I'm exploring the feasibility of building an
off-grid home.
The lot is in Southern Ontario, Canada, sorta midway between Toronto and
Niagara falls. The lot is well sheltered, ringed with pine/cedar trees,
averaging about 20 feet in height. It's dead-calm in the middle of the lot,
even with the wind blowing hard enough to bend the tops of the trees over
significantly. My (evolving) idea so far is incorporating passive solar,
and active solar thermal, a wind generator for electricity, with a diesel
powered generator for backup/supplement.
I'm not new to solar PV, or solar thermal. I currently have a 6 panel
Norsun thermal system that I intend to take with me (they're not currently
"permanently" setup, and it's mostly dismantled in prep for moving to temp
quarters until the house is built). With the design&size of the house, I
expect the thermal panels to provide about 70% of my heating needs (I will
be likely be using a forced air system, hot water feeding a heat exchanger
in the air plenum, as I expect to have some sort of furnace
(oil/propane/whatever to be determined yet, though most likely oil, if using
diesel generator backup)).
What I have *zero* experience with is wind generators. I'd really like
to hear any comments / suggestions / criticism from current/past
owners/users of wind generators.
I currently have no idea of wind availability at the site, so I've purchased
an anemometer with very rudimentary data storage, which I'll be mounting on
a 60 foot pole. I'll be able to collect data for about 9 months before I
actually begin to build, so hopefully I'll have some idea of the feasibility
of potential wind generation. The wind+diesel generation is planned for the
first part of the construction, to, well, supply power for the construction
of the house.
This is out in "the country", where I can hear my neighbor 1/4 mile down
the road cough on a calm, still, night. What kind of noise levels would I
be looking at for a smaller, one household, type system? Am I out of my
mind thinking about a forced air heating system with wind generation? What
do you consider reliable (mechanically) turbine/generator manufacturers?
Reliable charge controllers, inverters etc? If you could build your wind
generation system all over again, what would you do different?
I'd also like to hear from anyone who uses *small* diesel generators.
Has anyone collected any *real* data for quantity of fuel used per kWh
produced? I've done some theoretical projections/models, however, "real
world" data/experience would kick the crap outta any guestimated
efficiencies I plug into my spreadsheet.
(btw anyone done this with a VW 4-cylinder pre "tdi" diesel engine??).
Any and all comments, positive and negative, (except for the "isn't
economically feasible/smart to do if you have grid power nearby" type) are
most welcome...........I'm well aware how to calculate payback schedules, et
al, but that has very little to do with the drive behind my reasons for
wanting to do this.....it's for the engineering
challenge/keep-me-entertained/perverse-satisfaction/hobby kinda thing.
Thanks!
K. Jones
off-grid home.
of the house.
Thanks!
K. Jones
