I will install a device that prevents anyone with an alcohol level
over 0.08% BAC from driving. I am thinking of a keypad to enter his
phone number or social security number within xx seconds or something
better. I could try a breathalyzer, but this would be inconvenient to
other sober drivers. What are some of the best way (or device) I could
use to prevent a drunk person from starting his car?
One of the units specified by the courts who issue such sentences.
My bet is that the officially supplied-by-the-court units are considered
to be the *ONLY* devices that are acceptable for such use, period, world
without end, no negotiation, no nothing.
As in "Our terms, or you get to sit in the clink. Don't like that?
Tough! You shouldn't have been driving while drunk. Oh, you want to
argue about it? That's fine. Here ya go - Your parole (or whatever they
call it) is now canceled, go to jail, go directly to jail, do not pass
go, do not collect $200, end of discussion. Bailiff, remand him into
custody. Wanna open your mouth again so I can slap a contempt of court
charge on top of everything else?"
My further bet is that such devices *MUST* be installed by a specific
person designated by the court, otherwise, the perp is considered to be
refusing to comply with his terms of parole, and once again gets jailed.
Unless you're one of the people the court approves, and/or the maker of
the device being used, I dont think you've got a prayer of putting
together something acceptable. You might brew something up, sure. It
might even be better than what the court currently uses. But keep in
mind that part of the reason for these things is specifically to make
driving inconvenient/impossible for drunks. Secondary effect that's not
likley to be publically spoken: A nice bit of income for the court,
since these devices are usually charged to the offender as part of their
sentence, and the price of both unit and installation is deliberately
set punishingly high. Actual value is probably 10-20 bucks a unit, if
that, with an actual installation/maintenance cost of something like a
hundred bucks. Likely "sale price" to the person using it is likely to
be in the high hundreds, if not thousands of dollars, with the
installation cost likely being jacked just as high.
They aren't SUPPOSED to be cheap/easy/convenient. They're intended to be
punishment, and the more expensive, difficult, and inconvenient they can
be made for the drunk to use, the better both court and "Average
non-drunk-driver" on the street likes it.
