Hold on while Allen goes down the back shed and knocks something up. Sounds
like a real good DIY project that anyone can tackle.
Its not that hard, well as it appears, taking each item in turn:-
a. Is already in place, minor changes might be to add greater capacity for
oxygenated fuels like alcohol and methanol, lots of plastics and industrial
plants already use and produce those chemicals so the methods of storage
and transport are well known, consider this part already done for most
part.
b. Nature has already been doing this for ages, there is a huge ocean sink,
although this is harder it may well be the lowest priority item in
comparison with the others. Genetic engineering of fast growning trees
such as Pawlonia for example along with kelps and other seaweeds is going
to bear more fruit <pun> than much we can do on land. Kelp is is pretty
high demand not just for toothpaste.
c. Sequestering isnt also that hard though there are better places in the
word for it than others depending on geological factors. Not difficult
to separate O2 from N2 from air before feeding it to a combustion chamber
for producing heat for electricity, the resulting gas is mostly CO2 and
H2O, they are also easy to separate. We need political will along with
an alternative economic model that includes serious use of carbon credits.
d. We have heaps of sulphates in the ground already, if it were possible
to strip the SO2 from Calcium, Potassium and Sodium and replace it with
a carbonate then we have a heap of limestone, a great deal of sulphates
are used in inductrial processes though I'm not sure how much mroe than
carbonates. Its an option worth checking though. I also understand there
is research into methods to produce composites, ie Bond carbonates to
existing sulphates, there is a whole area of inorganic complexes that
may well be a suitable way to absorb CO2 and use the product as a
structural material, not an area I am expert in but having seen odd
inorganics for the last 30 years I think its worth pursuing.
e. Genetic engineering is growing by leaps and bounds, also need political
will to pursue this with more gusto perhaps along with a focus.
All the above needs a serious improvement in basic along with advanced
education, I am just not use that the OBE system is focused along any
lines to generate intellectual muscle to address the above points <sigh>
Regards
Mike
* GMC/VL Commodore, Calais VL Turbo FuseRail that wont warp or melt !
* High grade milspec ignition driver electronics now in development
* Twin Tyres to suit most sedans, trikes and motorcycle sidecars
http://niche.iinet.net.au
