Just starting out as a hobbyist in this great field...!!
For whatever reason, I missed out on a lot when I was a boy, so now as
an adult learner I'm working through "The Boy Electrician", published
by Lindsay Pubs. BTW, this is a great book filled with
fun projects that you can actually BUILD.
The project is an electric bell-ringer. I've gotten most of the needed
parts so far, the only problem I'm having is securing an iron yoke for
the magnet spools and also a small rectangular piece of iron or plate
to serve as the armature. I've scoured the net and have found suppliers
selling brass, steel, alum, etc, but no iron.
www.metalexpress.net ---- sells "cast iron" but it doesn't say if its
"soft iron" -
How important is it that these parts be iron? My thoughts is that the
plans call for them to be iron since it would increase the permeability
of the magnet spools and the armature.
I've heard that rotors often use iron. Maybe I'll try one from a
junkyard if the cast iron is too costly. How difficult is it to remove
the iron pieces from the rotor? I'm thinking they may not be the right
shape or size for the project. I have no experience taking apart this
type of motor, but I'm willing to give it a shot if it means completing
the project correctly according to plans.
Any suggestions/advice is greatly appreciated.
Thank you,
Chris
"soft iron" -
Thank you,
Chris
