Marvin
Bill said:Send the man a reprint, Marv! Or at least a scan.
I said I would on request. He hasn't asked for it.
Mark said:Betcha a nickel it's the biggest one in the solar system.![]()
Why not just use specific gravity or polarimetry to measure sugar
content and calculate alcohol from converted sugar?
That link you show is somewhat idiotic. An LED is not a white light
source but a mixture of primary colors (which you can see with a
compact disk used as a diffraction grating).
The link is confusing. One pic shows a white LED; the title implies
use of a 100W light bulb.
In my search for a simple way to calculate ethanol concentrations in
beer (of all things!) I remembered back to my college days - in one
biochemistry lab, we used a spectrophotometer to determine enzyme
reaction rates. Those Shimadzu spectrophotometers cost about $10,000
each, and had an on-board printer to print the resulting graph of
transmission vs. wavelength.
Oh, look, one can be built nowadays for cheap using off-the-shelf
parts:http://www.rsc.org/Education/EiC/issues/2007Sept/BuildYourOwnSpectrop...
I noticed one part is a 3140 op amp. Is this the one?http://www.mouser.com/search/ProductDetail.aspx?R=CA3140Mvirtualkey55...
Is there an easy way to do away with the requirement for *two* 9V
batteries and use just, say, +6V (from a wall wart, or 4-pack AA)?
Any input would be appreciated. Just imagine what could be done for
high schools, using/making one of these in labs!
Thanks,
Michael
I'll probably try that next. I've been putting distillate into a
graduated cylinder, weighing that, then using a density chart to get
ethanol fractions. Crude, but it (kinda) works.
Isn't the accepted way to measure the SG before and after fermentation
to determine how much sugar was converted to alcohol?
I make beer but never bother to measure the SG. Too much hassle, not
much you can do about it (beer happens) and there's risk of
contaminating the batch. There are some folks that claim it is
necessary to tell when fermentation is complete, but I find it easier
to control temperature and give it two weeks.
I did measure SG when I first started in 1990 - since a
hydrometer/thermometer came with the brewing kit I bought.
The only real reason to do it (that I can see) is to meet some
government requirement for labeling.
Single beam, single wavelength, crude, spectrophotometry is probably
not the answer for determining alcohol content. In the lab gas
chromatography was the first choice (another "easy" instrument to
build) then HPLC. Most HPLC can also be preformed with thin layer
chromatography (from what I understand) but TLC is better at finding
out what is in a compound than quantifying the amounts.
BTW we had an old Beckman spectro that used an auto light bulb for the
source and you adjusted the voltage (brightness) of the bulb to zero
the instrument then put the full cuvette in and measured the sample.
It was only useful for checking gross concentrations of substances
with relatively broad wavelength absorption. I'm pretty sure it would
be useless for alcohol.
Polarimetry may be a choice. Sugars twist light polarization -
optical rotation. It is a common instrument for checking sucrose
solutions. The instrument is a device with a light source, polarizing
filter, long 2-10" sample tube, with flat, optically clear, ends, and
a second - rotating polarizing filter before the detector. You
measure how much the second filter has to rotate to stop light from
reaching the detector between a blank (nothing in the cell or cuvette)
and the sugar solution.
Like SG it also has to be corrected for temperature - density.
Presumably you use maltose, I assume it would work with all sugars but
don't know for a fact.
Is this a hobby or business? Why do you care about alcohol and how
precise do you need to be? I have a few friends who are actual
chemists and do develop assays.
It's a hobby for now; it will maybe eventually become a business if I
get enough time and funding. It's for fuel ethanol, not for drinkable
ethanol. I'm actually starting with starch solutions (analogous to
making vodka from potatoes, or making sake from rice followed by
distillation). The requirement of hydrolyzing starch complicates
things a bit. I have to calculate how much alpha-amylase I need to
add to the starch solution, and how long I get them to react, before I
reach a set glucose concentration for the yeast to much on (I'd like
to keep it at no more than 200 g dextrose/L). Accuracy to 10% would
be great. Research as to how it's done in industry revealed that some
factories use on-line spectrophotometers to measure the ethanol
concentration within the pipes. That's what inspired this whole post.
I'd imagine dextrose assays would be more accurate than using
hydrometers...?
Thanks,
Michael
Your original post did say "beer." You lied.
I dabbled a bit with distillation. The usual technique is fractional
distillation in fractionating packed columns - I did nothing so
sophisticated.
Anything that makes it past the fractionating column(s) or thumper box
is alcohol and water and not sugar or starch. Different ball game.
~snip~
In beer and traditional whiskey we take grains and let them sprout or
just germinate for a day or two, dry and crush them then let the
enzymes work on the mash while the solution/suspension of malt and
water is held at 150 F. The germination converts a lot of starch to
sugar and the enzymes develop and react on the remaining starch while
the drying stops the development of a plant and chlorophyll and other
yucky tasting things.
You're seeming to imply you have pure starch with no natural enzymes.
That doesn't sound like it will produce fuel economically - since to
arrive at pure (dead) starch, you inevitably start with some natural
substance and remove everything else that might convert it to sugar
naturally. Vodka was made long before you could just go out and buy
amylase enzyme . . .
My feedstock is pretty much starchy food waste - kids' leftovers,
On Fri, 05 Oct 2007 20:06:47 +0000, mrdarrett wrote:
Have you tried getting methane from their poo? They have a virtually
unlimited supply of it, you know. ;-)
Cheers!
Rich
