Hello everyone present here.I am planning to build a transceiver operating at 30MHZ , for that i plan to make a coil of 5-8metres.That would be wound around on the inside surface of a rectangular metallic box and the end of the wounded wire will be soldered to the surface of the metallic box.Will this work as an antenna.Guide me,or ...will the taking out some portion of that coiled antenna outside the case
Be okay?
Be okay?
