Building a Faraday's cage ?
G
Guest
In sci.electronics.design John O'Flaherty said:
Another thought occurred to me. Could you mount another magnetic
pickup on the guitar in the same orientation, but not under the
strings? It should pick up exactly the same fields as the first, for
fields originating more than a few feet away. Subtract its output from
that of the first. Then it wouldn't matter if you moved around while
recording. I don't know what these things cost, but it might be
cheaper than a construction project.
See "humbucker" pickups.
G
GregS
I have noticed that with my guitar when I play I can reduce the noise to a
minimum depending on the orientation of the guitar. It would depend on if
the noise is omnidirectional or not but it might work.
With the faraday cage you might try some copper mesh and see if that works.
It should be relatively cheap to build. I seen them do it on Myth Busters.
I'm not sure if it will get the low freqencies though.
Another thing to do is to insulate the guitar's electronic cavities using
copper foil or a special paint. These will reduce the hum.
Besides those things you probalby know you can buy noise reducers, power
conditioners, etc...
Power conditioners can introduce noise. Guitars are terrible for noise.
I see Faraday cages all the time here. Mostly a 5 sided box with the front open. Most
of these cages are made from aluminum window screens. They reduce electrostatic
noise. Many times power strips are toward the rear of the cage, but NO AC 60 Hz
power can enter the cage area via power cords. I carry a electrostatic and magnetic
noise sniiffer. I recently added a photodiode so I could hear light noise.
Sources of the electrostatic noise can easily be tracked down, but ground
loops and 60 Hz wiring are simply tricky. Also around here, we suggested there be problems, so
new building are constructed with aluminum backed wallboard. It helps, but of course
its not perfect, but gets the job done of reducing intense fields. Having the AC wiring contained
in a conduit also reduces electrostatic noise to a very high degree. You can also
buy shielded AC cords. Isolation transformers usually help.
greg
John Jardine.
CS said:
So copper foil is enough ? How thick should it be or is that not important ?
Replacing wiring inside my walls is planned for a future (too expensive
now).
That massive 50Hz peak looks distinctly odd. Maybe it's not actual 'pickup'
but conducted mains leakage type currents.
Curiosity piqued, I stuck a 1.5H coil into a X100 lo-noise amp feeding a
normal spectrum analyser, looking at 20Hz to 1kHz with a 5Hz filter.
Just sat it on the bench near the incoming feeder, the only other powered
kit being the PC. Virtually no 50Hz component was present (-90dBm, 7uV) but
big peaks of 150Hz, 250Hz, 350Hz, 450Hz, all about 20dB higher at
about -70dBm, 70uV.
That was it though, all other components were sitting in the grass at
the -100dBm level.
Powering up a lot of other kit made little change to the display.
john
CS
U¿ytkownik "Rene Tschaggelar said:
20dB is not really a faraday shield, it is a toy.
And thus a single shield should be sufficient.
Low frequency is coupled magnetically, and magnetically
only. Thus iron should be sufficient. Iron means
iron and not steel, nor stainless, chrome nickel, or such.
By the way iron is better than copper at these frequencies.
Magnetic nearfield attenuates as r^3 and not as r^2,
I guess 1 mm or so should be sufficient.
Thank you very much :)
You need two cages inside each other connected
at a single point and earthed there to get a
decent attenuation. There have a filter plate
Is this due the wavelength ..? (one point at node, one at maximum = short)
where the signals are passed throuigh the walls.
The door and possible windows can be a problem
but are solvable.
For the lower frequencies, iron would be the choice.
I'd expect an attenuation in the order of 150dB
or better. Note that the quantum limit is at 180dB,
there is no better faraday shield.
How does this quantum limit work..?
Makes me curious.. :)
Phil Allison
"CS"
I have a small bedroom recording studio full of electromagnetic fields
(mainly 50hz+harmonics up to ~3,5khz from power cables in walls).
Here is how it looks on Adobe Audition's spectrum analyzer:
http://img158.imageshack.us/img158/4522/dirtysilence7th.jpg
I'm planning to build a 2m x 2m Faraday's cage/booth to protect active
electric guitar pickups from external electrostatic and electromagnetic
noise 20hz-96khz
** That hum is being injected MAGNETICALLY into your guitar's pickups.
A Faraday cage will have NO effect on it - whatever !!
FORGET IT !!
Your ONLY option to eliminate the hum is to get a guitar that has "
hum-bucking " pickups.
The hum problem YOU are having is WHY they were invented, way back in the
1960s.
Most musicians learn to live with it by orienting themselves when playing
to minimise the hum and/or using a *noise gate* to silence the hum when the
guitar is not being played.
BTW
I can hardly believe how many FUCKWITS posters here have given you the
WRONG answer for such a common problem.
....... Phil
H
Howard Eisenhauer
Q.- Do you have a PC & monitor running in your studio? Nearby?? The
switching supplies in these things, especially the cheap "No Name"
ones, are just F___ing horrible for generating noise, both radiated &
back fed on power lines. Those harmonic spikes on your mains
certainly arn't coming from your power utility, something is
generating them locally. If your guitar is picking them up out of the
air its VERY local. Have you tried connecting a 600 ohm termination
to the cable instead of the guitar to see if you still have the noise?
Beyond that I'd have to say theres also a problem with the cable
shielding setup, when properly terminated audio cables shouldn't have
any problem with cancelling out common mode or shielding differential
noise.
H.
Phil Allison
"Phil Allison"
to CS
FORGET IT !!
1960s.
** OK - it was actually developed by Seth Lover in the 1955:
http://en.wikipedia.org/wiki/Humbucker
........ Phil
Rene Tschaggelar
The first shield radiates to the inside what the
induced currents on it surface flow. The efffects
are multiple. You have to visualize the multitude
of frequencies and fields that are possible to
propagate.
The worst are nearfield magnetic, eg a train passing
5m from your house. At the time of CRTs, it was
impossible to work during the time the current flowed
through the rails. And it wasn't shieldable. As
John Larkin said, for a decent magnetic shielding,
eg 120dB up, you need substantial amounts of iron.
Me too... I haven't read through the whole theory yet.
Just the abstract. I guess the -180dB are the thermal
noise floor at room temperature in comparison to the
ambient EM-noise.
Rene
CS
U¿ytkownik "Phil Allison said:
"Phil Allison"
to CS
Hmmmm then why every good electric guitar (including mine) has a Faraday's
cage ( conductive paint or copper foil) inside - just for fun ? :D
FORGET IT !!
1960s.
I have two humbuckers in my guitar and i don't need another one. ;)
CS
That signal on my analyzer picture was recorded with crt monitor turned off.
air its VERY local.
All those spikes get louder when i move my guitar closer to the cable (going
to a ceiling lamp) inside the wall. The buzz gets quieter when i switch the
light off ( i even tried this experiment without a lightbulb to see if the
buzz comes really from the wire and not from a working lightbulb )
????? I know almost nothing about electronics , so if you can explain in
layman terms i would be grateful :)
noise.
H.
I think my cable is ok. It is high quality and short - it gives me no noise
when the guitar volume is turned all the way down.
Phil Allison
"CS"
** That is a simple * ELECTROSTATIC * shield - you jerk off.
Has NO effect on a MAGNETIC field .
** What guitar?
What "humbuckers" ??
I reckon YOU are full of SHIT !
........ Phil
Phil Allison
"CS"
noise 20hz-96khz
FORGET IT !!
1960s.
BTW
....... Phil
Phil Allison
""CS" = Complete Shithead
noise 20hz-96khz
FORGET IT !!
1960s.
BTW
....... Phil
propagate.
What distance and hole diameter should be used?, a prof suggested 1/2
wavelength for the holes at least. But things like micros have 1/65 wavelength.
I well not accept trains then ;)
ambient EM-noise.
Another perspective on this scale is that atoms work as wavelength conductors
depending on how large the holes between them are. So any glass have holes that
are at least 700 nm wide. While an parabole could use cm/mm wide holes and
still be conductive enough for radio signals.
CS
"CS"
It clearly has a big effect on power wires in my walls - i can hear a loud
noise if i put my emg707 very close to a wire in my wall and that noise gets
much quieter if i turn my guitar 180 degrees to face away from the wall and
hold the pickup at the same distance to the wire.
good enough - emg707 & emg81-7
Like everyone else few hours after a good meal ;)
jasen
noise.
guitars use unbalanced cables.
Bye.
Jasen
Phil Allison
"CS" = a Complete Shithead
gets
and
** YOU ARE A COLOSSAL FUCKING IDIOT !!! .
That scenario PROVES the direct opposite !!!!!!!!!!!!!!!!!!!!!
** Damn shame those two heaps of shit do not actually *buck* hum very well.
Try a " Les Paul " with original PAF Gibson humbuckers.
Bet it is silent as a graveyard in the same room.
........ Phil
CS
Ok if i am an idiot and you know better then you must be smart enough to
eplain to an idiot why "That scenario PROVES the direct opposite" ?
My guitar (in my room) is ~30 dB quieter than my cousin's (genuine) strat.
Do you realize that there is no humbucker on this planet that will buck 100%
of hum ?
