I have some questions about building a circuit on a bread board. Or more specifically correctly connecting said circuit to a powersupply/ ground.
The example circuit we where given can be found with the attached files.
As power supply we use the HAMEG HM7042-5 (picture can also be found in the attached files). So my questions are:
- Do I have to connect the ground on the left separately or can I just use the ground of the supply V1?
- We need to measure the outgoing voltage Vuit, to do this I presume I need to connect the wire to a ground and attach a voltage meter in parallel.
- If this is correct can I use the same ground of a power supply such as the one of V1?
Thanks in advance
Thanks in advance
