a. With the proliferation of Digital circuits and Digital Signal Processing techniques, Analog Electronics have become obsolete.
Is it true or false?
b. BJT’s are not used in large scale integrated circuits due to their large size and high power consumption.
c. Why use feedback amplifiers instead of conventional amplifiers? Explain the pros and cons.
The above three are the problem which I'm having difficulty finding the solution.
for question a, I understand that the we use more Digital circuits nowdays because they are easier to handle than Analogs, since Analog is most likely made by hands, while Digital can be made by machines. I do not think Analog Electronics have become obsolte because in order to interact digital electronic device with the real world, it will always need an analogue interface. I understand the pros and cos of Digital and Analog, but can't really explain whether Analog Electronics become obsole or not.
for question b, I know that BJT is used in IC, but not really sure about large scale IT. This is the question which I do not understand at all.
for question c, I simply don't know the meaning of conventional amplifiers. There was something called distributed amplifer, when I searched up for conventional amplifier. I know that feedback amplifier is good for stabilizing gain, reducing non linear distortion, and noise, but the bad thing is, it reduced the gain. Since I do not really know about the conventional amplifier, I cannot compare those 2 amplifiers to solve this problem.
Please give me an advice.
Thank you very much.
