H
Hammy
I have some steppers (bipolar 4-wires) from printers I would like to
test.
This is the motor I'm trying to test.
http://i40.tinypic.com/3532vrk.png
Full motor datasheet
http://www.mitsumi.co.jp/Catalog/pdf/motor_m42sp_6nk_e.pdf
I bought some Toshiba LDMOS bipolar drivers TB6598FN.
Typical application. This is my schematic exactly the same.
http://i43.tinypic.com/2kkh8n.png
Simplified block diagram of driver.
http://i43.tinypic.com/2gx3add.png
Truth table
http://i44.tinypic.com/2i0asl0.png
Full Datasheet TB6598FN
http://www.semicon.toshiba.co.jp/do...IC/TB6598FN_TB6598FNG_en_datasheet_060306.pdf
The motors are getting a regulated 12Vdc and the driver gets 5Vdc.
My questions.
From the datasheet for best performance my control signals should be
about 400Hz? 50% or less duty?
How should my control signals be for forward stepping?
The truth table just shows EN1&2 high,IN1&2 LOW. If I pulse IN1&2
they will go from forward to reverse and back again.
What should the sequence be to the four control pins for simple
forward stepping?
I'll be using a PIC probably just 12f508 for my control signals.
test.
Truth table
My questions.
forward stepping?
