This is a concept for a bike trainer I've been toying around with in my head for awhile, but lack the electronics specifics to really make anything more of it.
This isn't something I'm attempting now, it will be in the future aways, when I actually have a need for it or have the time on my hand to do it. The reason why I posted it in electronics chat as opposed to projects forum is I have no timeframe as to when I will do this and just want the information on a food-for-thought basis.
My idea was to build a frame assembly and have my rear wheel spin an alternator (as in from a car). That alternator would generate power, and a wattmeter would pick it up.
Thing is, most wattmeters I see simply plug in an outlet, you plug devices into them and they tell you the draw your device is putting on the wall. I need a wattmeter that would tell you the total amount of power created.
Now, it bears saying that for any of you familiar with cycling, this is not designed to be a replacement for a power meter, as I would also have to take my temperature and monitor that, the change in room temperature, and go through thermo calculations to determine overall power expenditure. To assume I would be 100% efficient at transferring muscular power to mechanical would be a GROSS overestimate - metabolic mechanisms are only ~40% efficient, and that's a hard-to-achieve number (car engines are I believe around 17%).
What I would be doing with that wattmeter result is taking it, applying it through a formula, and getting distance.
Here's my logic, tell me if I need additional considerations:
1. A single revolution of the alternator generates a potential and power. Whether or not it is measurable depends on things such as the gauge of the winding and other factors.
2. The wheel turns at a fixed ratio with regards to the alternator pulley. For every turn T of the wheel you get x spins of alternator pulley, and if one revolution generates power P,
T = x * P.
3. Concurrent to the circumference of the wheel, the wheel has to turn a certain number of times to make a mile. Therefore the amount of total power can be used to reasonably calculate distance.
I'd like to hear what some of you think.
My ideas always come out better when it's not just me thinking about them.
T = x * P.
