Luhan said:
The full size ones actualy work (slightly), the smaller ones just run
off the watch battery for a while.
Luhan
This was discussed a while ago in June about my experience with
Shake'n'Fake flashlights I got at the Harpers Ferry flea market. They were
only about $3 each. There is a little PC board in them, and one of them had
a resistor on it, but the wires from the coil were not even connected.
Others had the wires twisted together and stuck into a hole on the board,
and the "magnet" was just a slug of steel.
I actually replaced the slug with a magnet from an old meter, and I wired
up a little circuit with a 1N34 diode, a capacitor, and an LED, to see if
any useable voltage would be generated. After I shook it for awhile, I
measured the voltage on the capacitor, and sometimes found several hundred
millivolts. However, I discovered that it was just coming from the battery
through my hand.
The coil was only about 40 turns of fine wire. I wonder how many turns are
needed, or how fast the magnet must move, and how strong the magnet needs
to be, in order to generate enough voltage and current to light the LED.
There are some real ones for sale, but they cost about $20 or so, and I
heard that you can actually feel the magnet slowing down as it generates
power.
The lights I bought have a clear case, which seems like a cool idea so you
can see the mechanism, but actually it produces glare which makes it less
effective.
At the same flea market, I bought a couple of hand cranked lights, which
seem to work properly, although the mechanism will probably wear out if it
is used very much. They were about $5 each. Maybe they could be attached to
the handlebars and the counterforce from pedaling could be used to pump a
pair of them.
Paul
