G
Guest
Looking for input on a good schematic entry CAD. Will be doing mostly
digital circiutry.
TIA
Wendell
digital circiutry.
TIA
Wendell
digital circiutry.
digital circiutry.
The old DOS Orcad was the best one ever created by Man.
digital circiutry.
TIA
For me it was awful.
Meanwhile I've learned to deal with Orcad V10.
Helmut Sennewald said:If you finally want to make a PCB, then you choose the PCB program and live
with the schematic entry program that comes with it.
It's nonsense to buy any schematic drawing program and then later
buy a PCB-layout program from another vendor.
I disagree. Everyone should use DOS Orcad for schematics and PADS 2K for
the PCBs. Suggesting anything else is doing a disservice to humanity.
Ken Smith stated:
Does DOS Orcad has a *really easy to use* symbol editor? Ideally I would
draw the package, put the pins and forget it.
The library editor knows about two types of parts:
(1) Block parts:
With a block part you just get a rectangular box with pins around the
outside. This is good for things like RAM chips.
(2) Graphical parts:
A graphical part is made up of lines and arcs. You can also fill areas
but there are problems with the filling method on plots so I don't use it.
digital circiutry.
Ken Smith stated:
(1) Block parts:
This is exactly what is missing from EAGLE, or I am too blind to not
find it on EAGLE.
Looks good... I will try to find DOS OrCAD in one of those 'old
software' sites.
[]s
The old DOS Orcad was the best one ever created by Man. It had automatic
scrolling, block dragging and block moving. It also had a good macro
feature that you could use to quickly repeat operations. Many operations
could be repeated by just pressing the "R" key. This was ideal for
placing data and address lines. They had a clever mouse and keyboard
interface that worked well if you used one hand on the mouse and the other
to press keys. With a little practice, you could really fly through
stuff.
Amen, brother.Joerg
It is a bit clunky in EAGLE, but it does work.With respect to lib symbol editing
DOS-Orcad wins hands down in my opinion.
Mainly because it allows block mode.
0) If editing a device, save it and close it.
1) Open a dev (pac?) which contains the stuff you want to copy.
2) Group and copy.
3) Close the dev.
4) Open the dev (pac?) you want to edit.
5) Paste what's on the Library Editor Clipboard.
(Ah. It's a separate buffer!)
6) Save the pac.
7) Register the pac with the dev; save and close the dev.
digital circiutry.
TIA
Wendell
Are you printing the schematic or layout?FWIT , I just d/l Pulsonix Demo. I placed 3 = 16pin DIPs, 10 resistors.
Now try pinting. The print out is not 1:1. How the heck do I get a 1:1
print out of just these few parts?
Regards, Boris Mohar
