"Jeff Liebermann" wrote in message
No. It means hitting it hard with a high charge current.
Yuck. Why would I want to do that? If there were dendrites in NiMH
batteries like in NiCd, then perhaps it would make sense. Besides if
such a high current blast was necessary to produce a proper battery,
or to produce bigger numbers on the data sheet, the manufacturers
would already be doing it.
Where did you see this recommendation? I couldn't find anything with
Google under "NiMH slamming" variations, except under National
Institute of Mental Health. I did find this blurb that recommends
against the practice:
http://forums.dpreview.com/forums/post/25581821>
"Slam" is my choice of words.
I can't give you any references, but I've repeatedly seen in the documentation
for NiMH cells, that hitting them hard is necessary to get a "full" charge.
You are repeatedly warned NOT to charge them below 0.3C, and higher values are
preferable.
Perhaps my cameras and GPS require a higher minimum state of charge
than your flash? When I used to leave my conventional NiMH batteries
in the camera for a few months, it would usually be good for one or
two photos before complaining. I always kept a spare set of charged
NiMH with the camera in case I run out. They were also only good for
a few shots.
Most of my flashes are 500-series Canons, which are hardly wimpy li'l
critters.
http://www.stefanv.com/electronics/sanyo_eneloop.html>
Scroll down to the two pink graphs near the bottom of the article. The
conventional battery is down to half capacity in 75 days, and 1/4
capacity in 150 days.
That's not what I would consider "rapid" self-discharge -- other than,
perhaps, compared to a lead-acid battery.
Incidentally, this article:
http://www.stefanv.com/electronics/using_nimh.html>
covers quite a bit of ground on dealing with NiMH batteries, including
trickle charging, and a home made NiMH computah controlled charger:
http://www.stefanv.com/electronics/battman2.html>
and a simplified USB powered charger:
Most of my cells have been close to rated capacity. In one case, a cell was
about 20% low, and MAHA replaced it.
I didn't know that Maha made batteries:
http://www.mahaenergy.com/batteries/>
I don't know if they make them, but they definitely sell them under the
PowerEx brand. Thomas sells four for about $12. Considering that a charged
2500mAh cell gives about as much runtime as an alkaline cell, it doesn't take
long to amortize the cost.
Thomas sometimes sold the C9000 for ~ $40, but those days seem over.
I have two, so I don't have to wait if a lot of cells need charging.
I'm finding prices from $50 to $140 (including tax and shipping).
http://www.ebay.com/sch/i.html?_nkw=maha mh-c9000&_sop=15>
The eBay prices are nuts.
I was wrong. Thomas's holiday deal is the charger, a generic carrying case,
four Immedion AA cells and a plastic case for the latter, for about $52. Given
the cost of the "accessories", the charger nets at $40. This would be a very
good time to grab a C9000 from Thomas Distributing.
