Hi
Looking for best low-cost home PCB method.
(not mail-order service)
What's your recommendation?
My Requirements:
(not saying this must apply to you or anyone else)
Possible Options:
(does not have to be any of these)
Thx!
My Requirements:
- Cost: About $100 or $200 ish ($300 is pushing it, but would consider. $500 is too high).
- Gear Size: Desktop, small footprint.
- PCB size: at least 5" per side.
- Volume: Low (approx 10 PCB's per day, not 100's or 1,000's).
- Activity: Just for PCB's (eg, if you say "you can get laser-cutting, 3D printing, vinyl-cutting, milling, etc etc for only $1,000!", thx but too expensive.).
- Fiddliness: Minimal. Should not require a lot of annoying extra steps.
- Finickiness: Minimal. Should not depend too much on "getting it right".
- Turnaround: an hour max per board.
- Proven: not "maybe you could try...".
- Precision: can easily make SMD pads and traces.
- Chemical etching: acceptable (and you don't have to include etching instructions-- just method to prep the copper. That's the challenging part).
- Trace style: If it matters, my style is to remove very little copper.
- Quality: Reliable precision, accuracy. Clean traces.
- 2-sided: Nice to have, but not required.
- Availability: Current. (Kickstarter products are ok if they are actually shipping now).
- Links to actual parts, specific brands, instructables, etc.
- If DIY (eg modding an inkjet printer):
- 10 hours max build-time (a week or two, in evenings/weekends. A month is too long).
- No hard-to-find parts.
- No fancy shop equipment needed to build it.
- Well-validated, documented, kinks worked-out, no "experimenting".
Possible Options:
- Mill: remove copper (but cheapest mill i can find exceeds my budget).
- Laser cutter: remove resist (there are $100 laser cutters on ebay, but do they suck?)
- 3D printer: print copper? (not sure this exists).
- Inkjet: print resist (but, must be strong method-- most inkjet methods i've seen are too fiddly, finicky, and/or sloppy).
Thx!
