Best Book on PID ??
Jim Thompson
Recommendations for Best Book on PID ??
Thanks!
...Jim Thompson
Rich Grise
Thanks!
I hope I'm not em-bare-ass-ing myself here, but what exactly is "PID" the
acronym for? Somehow or another, I seem to have missed that one. ?:-/
Thanks,
Rich
Terry Given
Thanks,
Rich
Proportional-Integral-Derivative
Many, many systems can be suitably controlled by using a feedback
controller combining the three terms. Either with an opamp or a DSP (or
for that matter hydraulic or mechanical controllers)
Oh, and Astrom and Wittnemark's "Computer Controlled Systems" has a
pretty good treatment on PID. I have seen a better book, but alas forget
its title - its a chemical process control book.
Cheers
Terry
sparky
There is a book called PID Primer for sale on the these groups every now
and then. It seems to cover the basics very well.
And for Rich
PID = Proportional Intregral Differential
as applied to tuning instrument control circuits. This
applies equally to both electronic and pnuematic instrumentation.
Spehro Pefhany
Cheers
Terry
I've got one by Astrom, also the ISA book "Tuning and Control Loop
Performance", and Liptak's Process Control Handbook.
G
Gregg
Behold, Jim Thompson signalled from keyed 4-1000A filament:
Thanks!
...Jim Thompson
PID?
Jim....you really oughtta see a doctor :-/
;-p
Spehro Pefhany
Thanks,
Rich
Proportional-Integral-Derivative. It was invented more than 75 years
ago. It refers to feedback control with terms proportional to the
error, the integrated error and the derivative of the error wrt time.
(error being Process Variable (PV) - Setpoint (SP)).
Determining the three proportional terms is "tuning" the controller.
Over 90% of process control loops are PI or PID.
j.b. miller
Try www.quanser.com for some GREAT stuff especially the PID controls.
OK, I'm biased, I actually built a lot of his equipment and was impressed
with the precision of the mechanics and the true realtime software in
Windows.
Jay
Terry Given
of which 1/3 provide a significant process improvement, 1/3 provide
little or no process improvement and 1/3 make the process worse - due
almost entirely to the inability of users to tune them correctly.
I wonder if autotuning has helped the situation any - probably not much,
I imagine the installed base of non-auto-tuning units isnt going to be
replaced in a hurry.
Cheers
Terry
Chuck Harris
Best book? It all comes down to some nasty math.
"Servo Mechanism Analysis", by Thaler and Brown, is probably
as good a book as any... It's probably even on your bookshelf,
as it is a good 50 years old.
There is no easy way out of these problems, either you
characterize the open loop system, and design a proper
PID equation to control it, or you fudge things and
hope for the best. Computer based servo loops have made
fudging things much easier than it used to be... but I am
pretty sure, based on your relationship with computers,
that you aren't planning to do a computer based PID.
-Chuck Harris
Rich Webb
For learning (i.e., some math but not dense page after page of it) look
at "Control System Design Guide," George Ellis, ISBN 0-12-237461-4. I
have (and enjoyed) the 2nd edition of the book; the ISBN is for the 3rd,
published in 2004.
Web site, free companion software: http://www.qxdesign.com/index.htm
Spehro Pefhany
There are two aspects of this: the most obvious is the linear loop
dynamics, the classic Laplace-transform closed-loop response. Then
there's the far trickier nonlinear stuff: auto/manual control,
bumpless transfer, overshoot, integrator windup, process slew limits
(just ask a boiler to go from 0 to 100% steam flow in 30 seconds! Or
100 to zero, even worse!), autotuning, noise, feedforward, and
protection from runaway under various conditions. It's the latter
messy stuff that most of the textbooks tend to ignore.
John
You say that like it's a bad thing! ;-)
Best regards,
Spehro Pefhany
john jardine
John
True.
Spent early years on petrochemical plant control&instrumentation. Safe
pneumatics, 3-15psi range (Foxboro, Honeywell, Taylor etc). Air driven
analogues of all the elecronic stuff that's about now, such as square root
extractors, multipliers, mass flow computers etc. All process control by
pneumatic PID controllers/recorders. The control courses all offered
numerous pat equations for optimising the plant dynamics. We learnt to our
dismay the equations looked neat in a textbook but useless on real plant.
Most of the control systems ended up proportionally slugged down to near
stupidity, with only the occasional bit of integral to wind down sticky
setups. 'Reset' never had chance to get a look in.
I never did identify one of those mooted ideal systems that could be
classically tuned. The real world stuff had many processes at work in // and
they -all- interacted. Lowest common denominator was the tuning rule.
regards
john
Terry Given
John
Oh yes. One of the best papers I have read lately is:
"An Electronic Throttle Control Strategy Including Compensation of
Friction and Limp-Home Effects" Deur, Pavkovic et al,
IEEE industry apps may/june 2004 vol 40 no.3 pp821-834
These guys take the whole shebang into account. Interestingly enough
they optimise the large-signal step response by omitting the setpoint
from the P & D terms (something Astrom et al talk about).
Cheers
Terry
Ron H
Do you want to understand it or do you just need to tune it?
If the later, search on "Ziegler-Nichols". It's a technique that will get
your loop tuned and running smooth in short order. If the former, there is
no end to the options but before you spend money, search on "PID Controller"
and you'll find plenty of info.
73
K3PID
Ron H.
x-- 100 Proof News - http://www.100ProofNews.com
x-- 3,500+ Binary NewsGroups, and over 90,000 other groups
x-- Access to over 1 Terabyte per Day - $8.95/Month
x-- UNLIMITED DOWNLOAD
john jardine
John Larkin said:
[clip]
I did manage to fry a few hundred k$ worth of NMR probes a while back.
The main system control software (a c++ horror) would occasionally ask
my box to go to +3000 centigrade, so I dutifully turned the heater
power to max and waited for null. We had to add a battery-backed
serial-protocol blackbox recorder to our uP code to catch them in the
act. Then added a max_temp variable that can *only* be manually set
from the front panel of our controller. This controller includes a
setpoint slew limiter that creeps even slower when we're within 5
degrees of the setpoint, to guarantee no overshoot; a few degrees over
and we can poach an enzyme that a thousand rabbits died to make.
John
Well done. What's a few hundred k$ here and there. :) Would hope the C++
programmers were terminated with maximum predjuduce.
Best I've done is poisoning (ISTR) 10 tons of Platinum oxide catalyst. Was
told the stuff is biblically expensive but they never brought up its value.
At the time there was an explosion and fire and I'd been called out to
overide some auto ESD trips allowing isolation of a plant segment.
regards
john
John Popelish
John said:
Right. I've rarely seen derivative do much to a real-world process but
make it go nuts, the main exception being fast motion control servos. (snip)
Eliminating that overshoot is one of the uses of properly applied
derivative.
Jim Thompson
73
K3PID
Ron H.
Aha!! The perfect pointer! Thanks!
And what do you know, old "Nichols Chart" himself... last used one
about 40 years ago ;-)
...Jim Thompson
John Larkin
John Larkin said:
message On Tue, 23 Nov 2004 17:19:04 -0500, Spehro Pefhany
On Tue, 23 Nov 2004 21:28:09 GMT, the renowned Rich Grise
Thanks!
[clip]
John
Damn, topped again!
I did do some interesting things on a supertanker that earned me the
nickname "Lights-Out Larkin."
John
John Popelish
I am frustrated with industrial PID controllers that force me to
choose between having the P & D terms based entirely on error or
entirely on the process measurement only. What I often need is a
separate gain and derivative term for the process measurement and
setpoint inputs to the controller. This is almost always superior the
gain and/or derivative based entirely on error (setpoint - process
measurement) or base entirely just on the process measurement and lets
me optimize (after I define that word for the particular loop) the
process disturbance response and setpoint change response,
individually. For critical tuning, I have to use the feed forward
connection and external math to to get all the factors I need. Why
must I choose chocolate or vanilla when I really want a swirl.
