I think I may have just fried some rather expensive LEDs
I rigged up an LM350 as per this page (Constant Current circuit)....
http://diyaudioprojects.com/Technical/Voltage-Regulator/
Tried feeding it a 12V input voltage, used a 2R7 resistor in place of R1
The LED states a forward voltage of 2.1V@350mA to 2.3V@700mA (it's a high intensity power LED obviously)
Result... LED got very hot and I pulled the power quick.
I then tried my test meter across the LED - it was getting over 4.2V!
In series with the LED the current is coming out at 2Amp, which is the max the power supply can deliver! No wonder it got very hot!
I then tried putting a 470ohm resistor in place of R1, thinking this would regulate to a very very small current.... but no, I still get the 2Amp across the LED!
Circuit is obviously doing something, as the 12V has gone down to around 4.2V, but why is my resistor seemingly ignored?
I tried it with NO resistor - same thing.
Now I can't make sense of the calculations. I have tried three different LM350 devices, triple checked the pin config against the data sheet, and tested the resistor values with my multimeter.
Does that circuit just not work with an LM350 - am I being stupid?
I don't know what to test or do now, and I'm also worried I may have blown one of the LEDs. Can anyone offer any advice, or even a sanity check??
Are all LM350s the same? Do the pin configs change? Is it possible I have one with a different pin out? From left to right, with the bulge facing towards me, I believe the pins are Adj, Vout, Vin ..?
