Ok, guys I quit smoking and made my own ecig out of an old atomizer (the part with a coil surrounding cotton that soaks up the ejuice and gets vaporized by the coil) and battery from a broken ecig. It was pretty basic. I put a battery and ran 2 wires to the atomizer. I added a button on the negative wire to activate the ecig. I put the charging port before the button, in parallel with the atomizer. I added blue LED with a 1kΩ resistor on its negative leg after the button, in parallel with the atomizer which lit up when I pressed the button. That worked great for months until I wanted to add a charging indicator light. I added an LED before the button and in parallel with my charging port (and everything else) but DUH realized it would just be powered from the battery and always be on. So then I added a diode to the negative wire of the battery so that it could not power the LED. This seemed to work fine. The LED only came on when I plugged it into power (USB so about 5v). Then I realized that it had caused my battery to fail. It would only take a second to get to maximum charge, then only last for 1 puff before the battery died. What did I do to kill this battery? Or is the battery not dead and the diode is preventing it from charging correctly? How can I properly add a charg indicator light?
Here's my circuit diagram for it with a low rez picture of the device on the right. Not sure if I got it all right, but I typed it out correctly, if not in-precisely, above.
