battery decorations converted to mains tranformer
I want to create a Xmas scene for my fire place. I want to wire a number of battery Christmas decorations together and run it off a single multi voltage adapter.
The decorations are led lights only (some change colour) ranging from led tree light (3 x aa) and a number colour changing snowmen (2 x aa) and snow men and robins (3 x LR44 Button)
I wanted to create a box stand that they will be stuck down to and then wired underneath (hidden) and run off a single adapter.
Is this possible? Safe? If so how would run the wires?
multiple feeds off one wire or chain each positive feeding the next and same with neg?
Each light would have an led and a resistor to create a voltage drop and limit the current. (Apart from the button batteries)
So each circuit in each light is already designed for there battery voltages. If you can create several different voltage rails for each light it would be simpler.
If you used a single voltage for them all, you would need to find calculate which resistor is needed to create the right voltage drop for each(In addition to the resistors already in each light).
Diodes are useful to drop the voltage slightly, but it's more practical to use a resistor.
davenn
That's not really the issue
the plugpack will be wired into the existing battery terminals of each unit so that it still powers the unit for the colour changes etc
As @GPG said, a diode will effectively drop the voltage enough to the lower voltage light unit
no is isn't,. because a resistor will also current limit and in this case that also isn't an issue .... a diode is ideal :)
Dave
Hi Ash,
the diode would drop the voltage by approx 0.7v for each diode.
The resistors are more for limiting the current.
So two diodes at 0.7v is 1.4 volt drop immediately.
As for reliability, rectifiers are used in all AC to DC units.
So I would guess they are reliable.
Martin
I read somewhere before about the diode voltage drop changing when the load current changes. But I guess that doesn't apply here.
So its be possible to use one voltage supply and create a series network of diodes to provide the necessary voltage drop
