I have limited electronics knowledge but know how not to kill myself around them, I have done a lot of research on the subject but just need someone with the know how to connect the dots and give a solid answer. I am looking at buying an intelligent battery charger however it only fits AA/AAA. I have a 18650 type battery and would like to charge it intelligently.
The charger I am looking for is similar to this
http://www.amazon.com/Ambient-Weath...elligent&pebp=1422046482981&peasin=B00LUZHL4C
So my three questions are
1) Can I just put a wire from both terminals of the charger to the terminals on the 18650 3.6v battery. Will this just trickle the juice in until full or will the charger realise 3.6v is way too high for the AA / AAA battery that it is expecting and either not work or cause a disaster
2) If the above is bad then is there a way to test a dumb charger while its charging as to when it is finished. I have a basic multimeter and wondering when the battery is taking a charge does it show a different current compared to when its fully charged. Does it behave differently and if so what is an example of the difference between taking a charge and full. And where should I put the multimeter terminals. I seen a Russian video where he put a piece of copper between the bottom of the battery and the bottom clip of the charger. Then he touched one multimeter terminal on the copper and the other just on the back of the bottom clip of the charger. I have absolutely no Russian so wanted to ask if this makes sense to you guys.
6:15 minutes into the video
3) If the above isn’t possible then finally I believe you can test a battery with a multimeter but need to put it under a load. Can anyone send me a link of the resistor that is needed to do this.
Thank you so much for your time
paul
paul
