Hello gang!
Recently I purchased two 6/12 volt battery chargers with 2 and 6 amp modes at EBAY. A liquidator was ditching for Harbor Freight, made by Chicago Electric. Retail is $60 for both and I paid $19 for both including shipping knowing that both were not working. Thought I could get at least one if not both going and now am having some problems. Manual states they don't sell replaceable parts, and I have at least one bad part. The diode in the bottom right corner of first BAT charger (see pic of circuit board) gets very hot when plugged into mains for a few seconds with battery attached. The board has two diodes labeled scr1 and scr2, and they are stamped as BT151 25J TRANSUN. Ebay sells similar SCRs for $4 including shipping. I suppose I could swap good diode from other charger but that one works fine.
The second charger was also DOA originally. Noticed that there was no continuity on one of the primary leads so I moved to a different lead and now secondary output tests ok so one charger appears to be working already.
Woody
Woody
