Thierry Nouspikel
Hi there,
I need to back a low-power SRAM with a coin battery, so that its
contents remain unaltered while power is off.
The power part it easy: I'll just connect both the battery and the
regular +5V power to the Vcc pin of the SRAM, each via a diode (e.g.
1N4148).
But I have more problems with the CS* pin. This SRAM has no active-low
standby pin, so the only way to put it in low-power standby is to hold
CS* high when power is off. This could be done by connecting CS* to the
Vcc pin via a 4.7K resistor.
However, how am I to drive CS* during normal operation? If I use a
standard TTL gate, it will drain the battery through the resistor when
power is off.
I though of a complicated scheme using a PNP and a NPN transistor, but
I'm sure there must be an easier way. For instance, would a 74HCT do the
job or will it also drain the battery?
Thanks for your help,
Thierry
1N4148).
power is off.
Thierry
