I have an old battery back-up system for a household computer which uses a 12 Volt battery.
I want to substitute a 12 Volt deep cycle marine battery and use is as a backup for the electric sump in my basement.
I'd like some guidance on selecting the correct battery for the job. Since the sump is on a float switch and doesn't run full-time, I thought with the right battery, I might be able to get many hours of battery back up.
So again; I know that the pump is 9 amps. What else must I take into consideration? If I wanted 24 hours of back up, How do I determine the number of batteries needed?
How would you approach this project?
Thank you in advance.
Nic
Nic
