Sir Azlan . . . .
On my original plotted schematic for the 999, the unit concept is the
SAME as yours in the power supply ( the right half of schema)
You just need more relevant info on the left sides
YELLOW marked up VFD panel portion . . . . .s o o o o o . . . . .
Here is a custom
UNITIZED schema of the Aiwa Z1800, of
ONLY the relevant circuitry of one otherwise, somewhat co-
MMMMM-plex schematic of your unit.
The very top portion is being relevant to the visual display unit as the RED flagged unit and some relevant injection of the minus 30 volt VFL supply voltage .
In addition, the display units extreme ends . . . of pins 1-2 and 48-49, are receiving a constant AC voltage of ~ 5.5VAC from terminals 11 and 17 of one of the PT1 power transformer windings.
GREEN arrows are the power flow for the panels filament strings.
BLUE arrows are the VFL negative 30 DC volts supply for the display.
The -30 starts on the PT1 with a secondary of a power audio supply winding . . .with Term 14 ground and Term 16 supplying ~28 raw AC via the
PURPLE arrow path to get voltage doubled with D106 and D107 . . .filtered with C106-107-108.-109 E-caps.
Then Q102-Q112 along with Zener D114, regulates the now DC supply, on down to -30VDC and exits as VFL supply via the
BLUE arrow path.
This relevant schematic portion is also being
BLUE flagged with its support / construction components..
In the upper schematic portion, there is another, likewise,
BLUE flagged area with its support components.
Sooooooooooo . . . it now just looks like you need to place meter probe ground on CONNECTOR 601 or 101 pin #21 and power up the unit and probe pin 20 to see if you have the NEGATIVE -VFL voltage . If not, research at its point of origin back in the power transformer area.
Then, switch metering to AC mode and check between pins 15 and 16 of CONNECTOR 601 or 101 to see if you have the filament voltage for the display. Finally lift either the 1-2 or 48-49 wiring end to disconnect the AC filament supply line, and test across the filaments to confirm flament continuity..
Or in a TOTALLY dark area you might be able to see the frontally spaced out filament strings light up, HOWEVER, they do run at a VERY, very dim orange.
AIWA Z1800 . . . . . UNITIZED SCHEMATIC SNIPPET . . . .
https://i.postimg.cc/Zbyr69hq/AIWA.png
Thaaaaaaaasit . . . .
73's de Edd . . . .
Having . . . Fun . . . Fun . . . FUN ! . . . at work . . . . .
Put decaf in the coffee maker for 3 weeks.
Then, once everyone has unbeknowingly and gradually gotten over their caffeine addictions,
Switch to espresso !
then . . . . its . . .
https://i.giphy.com/media/j2MdMFNumkFeAAxfch/200.webp
