With all semis out (as they are now) perform the test from post #18:
Tets resistance between output (L1) to GND and ±68V rails.
And ±68V rails to GND.
note:make sure there is no voltage on the ±68V rails(big caps discharged).
Re-check resistors R97-R106(in circuit is fine).
With TR27 and TR32 shorted C-E no wonder the fuse blows ,
it creates a current of about 145A 2x68V/(2*0.47ohm).
About the heat-sink issue:
It is usually connected to GND(verify that).
which of the TRs had the insulation under it?
What kind of insulation was it?(clear mica,silicon pad)
Was thermal paste used(for all TRs)? Was it "dry"?
Was the "back" of the TRs(for all TRs)plastic or metal?
Where the tightening screws tightened enough?
As It is ,it is hard to say what caused the Final TRs to blow.
could be a thermal problem or a shorted output.
Did you check the connected speakers(do check them now, ohm test).
