Pygmi
I just started my first time critical project with AVR's.
And time critical meaning interrupt response times.
So far I have been using avr-gcc (3.3.x) and I have been
pretty happy with it. And I have written ALL code in C.
I'm hoping to get some code executed within 2 us or so
after external interrupt (INT0/INT1 with ATMega32).
I wrote the code to be executed today and ended up to
appr. 20 instructions/cycles. With 16 MHz clock that
means something like 1.25 us. Nothing much to optimize
there.
From datasheets I have found out that it takes 4 cycles
minimum (?) to jump to interrupt handler. By adding some
register saving and stuff, I was expecting less than 0.5 us
to start executing my own code => resulting in <2 us.
Ok, that was what I was hoping...
When I compiled the code and ran it, I noticed that it
took about 2.5 us to start executing my code?!?!
(I used ATMega8 as I don't have any M32 at the
moment, but I guess it isn't relevant??)
I checked the list file and one reason is the
LENGHTY prologue added by gcc into interrupt
handler (17 instructions!!!), saving LOT of registers...
Two questions:
1. Even with 4 cycles + 17 instructions there is 1 us
missing?? What else happens before my own handler
code starts executing?
2. Is there any way to tell gcc NOT to 'push' all those
registers in to the prologue??
And finally:
If I expect to have my own code to execute
within 0.5 us, is the assembler the only way to go??
Thanks for any info in advance....
Any links to good resources are appreciated as well.
I REALLY like to know exactly what happens there.
Pygmi
there.
Two questions:
And finally:
Pygmi
