AV Sender interference
F
felix_unger
which reads you dont understand and lack imagination
well we weren't talking about radios or routers, so I don't know what
your talking about
rgds,
Pete
“If Julia is the answer, then what was the stupid question?!”
"Julia finally got something right. Older people don't vote Labor, because they have seen too many incompetent, mismanaging, money-wasting Labor governments"
“It doesn't matter [who the leader is] the Labor Party is rotten, the policies stink, the lies insufferable, and the waste intolerable. The Muppets could do a better job!”
“All that's needed now is a small miracle to rid us of the worst prime minister and the worst government in Australia's history”
"If the WORLD as a whole cut ALL emissions tomorrow, the average temperature of the planet's not going to drop for several hundred years, perhaps over on thousand years" - Tim Flannery, Climate Commissioner
"It is a remarkable fact that despite the worldwide expenditure of perhaps US$50 billion since 1990, and the efforts of tens of thousands of scientists worldwide, no human climate signal has yet been detected that is distinct from natural variation" - Bob Carter, Research Professor of Geology, James Cook University, Townsville
"Currently, China and India combined emit 20 times as much as Australia each day, and that factor is increasing rapidly. Australia's annual savings by 2020 could be emitted by China and India within five days" - Dr. David Evans former Govt Climate Adviser.
“What I see is a country bravely beating along to the agenda of some ideological people, in this case the socialist left of the ALP and the Greens, to take away what is a natural advantage. At the end of the day, we are paying someone else to use our coal” - Peter Costello, former Federal Treasurer - http://tinyurl.com/costello-carbon-tax
“Wayne Swan threatening the Banks, is a bit like being savaged by a dead sheep!”
F
felix_unger
the reason you get interference is signal strength or rather lack of it
either you get more signal
not possible the output is fixed
or move the tx and rx closer
not possible either
do you have trouble understanding that ?
no
the more walls in the way the less signal
yes
rgds,
Pete
Clocky
your talking about
He's never had a clue on any subject, ever.
No surprise then that the halfwit isn't on the same level as everyone else.
F
felix_unger
Went down the same road, and eventually settled on a 2 channel good
quality modulator:
http://www.electrocraft.com.au/Products/EC_StockInformation.asp?stockNo=157
I send cable TV down one channel, and my CCTV system down the other.
Allows you to use any TV set for cable, or CCTV monitoring. :)
Requires a little extra to make it work:
http://www.electrocraft.com.au/Products/EC_StockInformation.asp?stockNo=2672
and a little rewiring, so that you have the modulator feeding
everything, but if you want to spend the time and money, you will end
up with a top result.
Cheers Don...
Hi Don. Thanks for putting me on the right track. :) I am going with an
analogue modulator with a dedicated RG6 run to proximity of the second
set, and splicing it into the antenna feed (to that set) with a combiner
splitter. I tested with cable just running loose through the house, and
it works fine. clear picture and no interference. later I might invest
in a better modulator, but this will do for now. now if the damn rain
would just stop, I can set it up properly! Thanks again.
rgds,
Pete
