Australian supplier of 'virgin' 20 pin ATX connectors ?
Sean Lincolne
Can anyone recommend a supplier of unused 20 pin ATX connectors ?
I'm building a computer in a case based around a VIA ITX board, and
rather than use the standard connector that came with the DC-DC
converter, I want to reterminate my own.
My aim is to avoid having any slack cable inside to save space and avoid
any airflow problems.
There's nothing listed on DSE, Jaycar, or Altronics, and I could not
find anything useful on Farnell's web site.
There seem to be a lot of people selling just the nylon bit (case
modders mainly).
Can anyone suggest an Australian source ? Even just the pins (albeit
the little buggers are square and rare) would be great.
Please reply to this newsgroup - the reply email address does not work.
Thanks,
Sean
budgie
(snip)
We consume a few in the form of pre-made ATX-ATX extension harnesses for <$10
each, to accommodate a "special interface" in-line. Couldn't find a source for
connectors/pins so we went this way, which for our application saves a lot of
termination time anyway. These are ex pccasegear and WES.
Russ_Verdon
Your other option is shorten the cable inside the power supply. Desolder
each wire where it enters the power supply circuit board, shorten to length
and resolder back in place. If you do one at a time you shouldn't get into
trouble. This way you don't have to worry about the connector at all!
This assumes you have reasonable soldering skills and check that uou don't
cause any solder bridges.
Regards
Russell
Sean Lincolne
Unfortunately my dilemma is that the cable that leaves the PSU board is
not soldered in.
The PSU comes with a cable with an ATX connector at each end (it's a
MiniBox M2 DC-DC converter) so I can't do that.
Worst case scenario I can simply cut bits out of the centre of the cable
and then rejoin them - but that's ugly :-(
Ross Herbert
modders mainly).
Thanks,
Sean
Page 37 of the ATX12V Design Guide gives particulars of the Molex 24
pin main power connector.
http://www.formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf
Whether you can buy them in small qty is unknown.
matt2-amstereo
technically only 7ish connectors are actually needed because there are
only 12 -12 5 -5 3.3 pgood p-on *the different colours* there are
multiples of each one for load sharing purposes (the many grounds and
+12 (yellow) that are doubled up) in reality if the load is light (via
epia's) you only need one of each colour,maybe even ditch the -5 and -12
cause they are for legacy etc
Sean Lincolne
Unfortunately my problem is finding an Australian distributor for any.
Whether I get 7 or 20, the problem is still the same.
I'll probably end up getting them from the US - Mouser have them in
their catalog - at US$0.17 each.
Sean Lincolne
Thanks,
That's the plug (not what I'm after) but it looks like they have the
pins (269220 - Molex part 39-00-0078) - at $49.55 + postage for a pack
of 100.
I can buy them cheaper from the USA.
Probably the smart thing to do :-(
Sean
F
Franc Zabkar
of 100.
.... plus GST
Have you tried Molex Far East South Management P/L?
Lvl 7, 91 Phillip St Parramatta NSW 2150
t: 02 9707 4977
f: 02 97933577
Alternatively, here is a compatible part (AMP 794421-1):
http://ecommas.tycoelectronics.com/...wing794421ApdfEnglishENG_CD_794421_A.pdf
Try contacting Tyco Electronics:
http://www.tycoelectronics.com.au/home
- Franc Zabkar
