Hi Guys, This might be a bit of a different question. I have a sound generator for my model railroad. It generate the sounds of locomotives as I operate them. It is triggered by voltage changes as I move the rheostat throttle. This power pack has screw terminals. The instructions say to run the two screw terminals by wire to a 4 inch 8 ohm speaker. What I need to do is to run the wires from the two screw terminals to my mix board so I can take control of the sounds and shape them E.Q. wise and then amplify without distortion. The specs on the speaker out of the power pack says "1 Watt Audio Power into 8 ohms impedance 65db signal to noise ratio". Are you aware of a converter box or something that would work well for this? This is outdated technology but I want to bring out the best of what is there. I thought I would ask you folks as you have never steered me wrong in the past.
Thanks, Tim
Thanks, Tim
