audio amplifiers: +/- X VDC vs 0-X VDC
I've noticed some audio amplifiers, like this one, need +/- 35VDC:
http://www.national.com/mpf/LM/LM3886.html
and some amplifiers are happy with 9 to 18VDC, with respect to ground:
http://focus.ti.com/lit/ds/symlink/tpa1517.pdf
Besides the obvious difference in power, how come one needs +/- power,
and the other is happy with 0-X power?
In the second case, for "no audio signal", is the speaker suspended
halfway between rest and max, resulting in only half of the available
speaker movement range?
Michael
I've noticed some audio amplifiers, like this one, need +/- 35VDC:http://www.national.com/mpf/LM/LM3886.html
and some amplifiers are happy with 9 to 18VDC, with respect to ground:http://focus.ti.com/lit/ds/symlink/tpa1517.pdf
Michael
Split supplies don't require an output capacitor on the amplifier.
Those can get big and expensive for high power levels.
GG
BobG
If you have two amps running from one power supply and one is
inverting, they call that bridge mode. One terminal goes up and the
other one goes down. If there's no audio they both sit at the halfway
up point. Used to be that would come out on a phone jack or a bananna
plug, but the Europeans got worried and made everyone use Speakon
connectors. So now we are all safe.
Jamie
Michael
If you look a little closer at the PDF file, you'll notice that the
voltage range is not locked at 35 volts. It'll operate down to
20 volts.
And as for the question about you speaker output center point. If
you look at the how they label the power supply lines and also include
a ground symbol in the print. This means the chip is expected to be
connected to a dual out put supply with a common ground. the output will
have differential polarities. + & - and a common. when the IC is at the
center axes point of the signal. the + and - sides are equal and thus
cancel each other out.
If you were not using a dual polarized rail supply, then you would
have problems because the design would force you bias the IC so that the
output is generating 50% of the supply voltage. In this case, you'd need
a decoupling cap.
It's best to use a dual rail supply so that you don't use a cap on the
output. Caps change value over the spectrum and thus can inductively
interact with other components on the line. This does not do well for
achieving a flat response!.
E
Eeyore
Because audio requires both positive and negative pressure variations and
that's most readily created by appling positive and negative voltages to a
loudspeaker.
They AC couple the signal to achieve the same thing. This requires extra
components etc.
The speaker moves BOTH ways. NO, you don't apply DC to a loudspeaker for zero
signal. You'd burn out the voice coil for one thing.
Graham
E
Eeyore
a decoupling cap.
No, you'd need a COUPLING capacitor.
Graham
Jamie
Eeyore said:
Graham
Ignorant sap sucker.
Go back and count your marbles, I think you've
lost some.
Michael Black
Michael
Some of this is illusion. You can have a dual supply for an op-amp
or audio output amplifier, and then the "resting point" is at zero
volts.
But you can have the same circuitry running off a single supply, but
then you need to bias the opamp or output amplifier so it rests
somewhere in between the positive voltage and ground, often right
in the middle. It gives you the same effect, the only difference
is really where you measure the voltage from.
With a single supply opamp or audio amplifier, your DVM's negative
lead going to ground would show the output voltage to be 1/2 the
supply voltage (we're generalizing here). But, if you put your
negative lead to the point that biases the opamp or output amplifier,
and then measure to the positive supply (ie put your positive lead
on the positive supply bus), you'd find half your DC voltage. Connect the
positive lead to the ground of the amplifier, and you'd read a negative
voltage, equal to the value you saw at the positive line. (This is
assuming the opamp or output amplifier is biased at the half-way point.).
How do you get a negative voltage when you aren't powering it with a
negative voltage?
It's all a matter of reference point. In both cases, you have your
ground lead at a point somewhere between the supply lines. Both
basically give you the same effect.
But of course, if you bias the amplifier input at half the supply
voltage, you only get the swing of the supply voltage (likely a bit
less). ANd the resting point of the output will be half-way between
ground and the positive supply. You can't connect that to the speaker,
the DC voltage will cause problems. Return the other speaker lead to
the same bias voltage, and that DC component goes away. Of course,
then that DC voltage at 1/2 the supply voltage will have to handle
the current of the output stage. Or, you can go the normal way,
putting a coupling capacitor at the output, which strips off the
DC component.
You will need higher voltage if you want more power, and at
that point it likely is worth adding a negative supply rather
than double the voltage and dealing with the DC component on
the output.
As someone pointed out, another method of getting rid of the
DC component is to feed the other side of the speaker with
an out of phase audio signal:
Audio ---------------AMP1 --
| speaker
|--inverter----AMP2---
Both leads of the speaker sits at the same "resting point",
ie half the supply voltage. So it's not seeing a DC component.
But since there is an inverter stage between the audio signal
and the speaker, the audio signal to the speaker is different
on each speaker lead, and the audio comes through.
Michael
Don Bowey
lost some.
There is nothing wrong with using a wrong term, but why show your ignorance
over it by arguing when someone corrects the term? It is, after all, a
coupling capacitor.
Jamie
coupling capacitor.
Yes, that is true, It's also termed Decoupling capacitor because of
the interaction of what it's used in.
Coupling a circuit via a capacitor is just that, coupling. how ever,
using a CAPACITOR to isolate DC voltage (which is where the original
contents of this started) is termed as Decoupling capacitor which is
more to describe in what it's doing and not what it is.
Any one that has really been working in the field knows this how ever,
I find those that just sit there arm chair wise and recite text book
literature and proclaim to be experts are just ignorant to say the least.
Graham, or is it Mr. HAM? the little snake in the grass.
E
Eeyore
It's not called anything of the sort. You're just making stuff up as you always
do when (as usual) your mistakes are found out.
Utterly WRONG.
You can call it a DC blocking cap OR a coupling cap. But it is NOT a *decoupling*
cap !
You are the most monumental moronic fuckwit.
" In electronics, decoupling refers to the preventing of undesired coupling
between subsystems via the power supply connections. Nowadays, this is commonly
accomplished by connecting localized capacitors close to the power leads of
integrated circuits to act as a small localized energy reservoir; these supply
the circuit with current during transient, high current demand periods,
preventing the voltage on the power supply rail from being pulled down by the
momentary current load. See decoupling capacitor. "
http://en.wikipedia.org/wiki/Decoupling#Electronics
Graham
Jamie
Utterly WRONG.
cap !
Graham
Arm chair text book rookie!.
All show and no go!.
Don't feel alone, I work with them
quite often. All living in their ideal
world!
There are many very smart and talented
people in this group that I say deserves a lot
more gratitude than what they get. You how ever, aren't
one of them.
Now go count your marbles and go to bed. Let some one
else use the community computer.
It has everething to do with application. WHY buy 90v amp when it will se 12 v for car radio. why use 90 volts on audio amp Simple dynamics more swings on the output
Don Bowey
world!
Wow. Is your mother a regular lurker on the board?
You how ever, aren't one of them.
Oh well...............
world!
one of them.
Not only are you wrong, you're also rude and poorly behaved. Graham
has it right. Of course that is what he does for a living so it is to
be expected.
GG
volts.
negative voltage?
DC component.
the output.
| speaker
Michael
It's making sense now!
Thanks everyone
Michael
Rich Grise
As someone pointed out, another method of getting rid of the DC
component is to feed the other side of the speaker with an out of phase
audio signal:
| speaker
Geez! Inverted is not equal to "out of phase". They're precisely in phase,
simply of opposite polarities.
Please don't confuse the newbies.
Thanks,
Rich
Jamie
be expected.
GG
And what do you think I do?
I can only expect an ignorant answer only because;
1. You don't know me.
2. And I really don't think you know Graham? or Mr. HAM.
How ever, if you watch the treads pass by like I have for several
months before I voiced my opinions. I have come to learn
who is and who isn't worthy of respect.
Before giving out your ignoramus views. Maybe you should be
more in touched with reality.
And don't bother asking what I do, neither you or any one
else gives a shit what you or I do for a living. All that
really matters here is, I can see it coming a mile away. And
what i'm seeing, isn't impressing me at all.
