Hello,
This is my first post on this forum and I look forward to participating in the future.
I am trying to teach myself the basics of electronics. I have bought the textbook and lab manual that is used at my local community college for the first course in EE Technology.
I have run into a road block in the lab manual. It tells me to buy on-line a 1 watt power amp kit that has a voltage gain of 1. (Later in the instructions, I am supposed to connect a speaker to the output of the amp and supply the amp with a 1KHz sinewave. )
I have found on the Internet 2 audio amp kits that have a power gain of 1 watt, but both of the amps have a voltage gain of at about 30db.
First, does anyone know where I can find a kit that is described in my manual? If not, can you direct me to a schematic for such a circuit?
Second, I am confused. If the amp only has a voltage gain of 1, is the current being amplified, at the max, to 1 amp. so that the formula P = VI results in a power gain of 1 watt?
When are voltage gain audio amps used and when are current gain audio amps use? Does it make any difference?
Thanks for your help.
