Michael
Hi - when you're etching your own circuit boards with the iron on method -
lining up the sides of a really fine two sided board can be really
difficult. So today I was thinking that instead of battling that - why not
just get two boards and only etch one side of each - and then drill all the
holes and then glue them together.That way all the holes would be lined up
perfectly (well if you can drill straight that is) The only problem I see
is added cost and added thickness. So to combat the latter of those two -
has anyone seen any really thin single sided copper clad boards? thanks,
Mike N.
Mike N.
