mm
Are all IR emitter heads transparent to IR light from a separate
remote control.
The one I bought has a translucent red plastic head but doesn't say it
is, but another one does say so. Is the second one just better at
marketing?
Online I bought a 3-headed IR emitter, like is used when the AV
equipment is kept in a cabinet, and I was very happy.
Then I looked at another one and it said " They're made of material
that's transparent to IR light, so commands can still pass directly to
individual components if desired."
Details.
This is a PREMIUM IR Extender Hidden Infrared Repeater System Kit and
its description includes: "The 4 emitters included can control many
different A/V devices. They're made of material that's transparent to
IR light, so commands can still pass directly to individual components
if desired. You may stick the emitter over the IR emitter on each
component, or place on the shelf in front of the component if you
prefer - they're powerful enough to get the signal to the component."
But when you click on the emitter, which is sold separately also, it
says none of this!
http://www.cmple.com/p-209-dual-ir-emitter-mini-stick-on-infrared-emitters-blink-eye.aspx
I hope they are all IR-transparent like this one, especially the one I
bought an hour ago. To work with the Leapfrom or whatever I end up
with.
remote control.
marketing?
Details.
says none of this!
with.
