Joel Kolstad
Just curious... has anyone used an active filter at 30MHz or higher? I'd be
looking for a second order bandpass filter up there, and using a state
variable topology I'm reading that the GBW of the amplifier needs to be at
least 3*Q*f0... and I can live with a Q of about 10-12.5, so that would
indicate a GBW in the ballpark of a GHz. Analog Devices will such you such
an op-amp, but is it going to very difficult to get the filter to perform
properly when the GBW is the same as the '3*Q*f' formula? Or does that
formula assume you'll spec the op-amp's GBW directly from it?
Other than LC filters, are there other common methods for HF range filters?
Thanks,
---Joel
Thanks,
---Joel
