Hi all,
The guy who sold me some DC transistors said they would be fine to use with an Arduino. Having recently been exposed to the guaranteed isolation provided by SSR's I worry that if this transistor was used or exposed to anything near what it is capable of and things go wrong it could blow the Arduino.
I was thinking of adding a fuse, but am unsure if this would be a correct solution to the problem. The max voltage the transistor can use is 600, and the Arduino uses 5v for its pins. The Arduino max amps is 40ma, and the transistor can sustain 32A.
Can I use an SSR for DC applications? They all seem to contain TRIACS and I am unsure if this is suitable. Is it all ok without the fuse?
Thanks in advance for any help.
Dan
Dan
