What does Russia do?
I am reminded that there are several ways to break encryption.
https://xkcd.com/538/
Emotion?
???? = emotionThe FBI should have the talent????
Couldn't they simply remove the flash chip or chips from the device and read them something other than an iPhone? I doubt that the program that erases everything after 10 wrong keys are entered would be inside the flash chip.
The data is presumably encrypted, but there are only 10000 possible 4-digit keys, easy enough to crack.
Bob
Words like "Couldn't they", and "I presume" indicate speculation, not certainty.are u sure? you need more truly source about this topic.
I already covered that. It is a separate chip.Re: remove the Flash
Bypass the operating system and get to Flash directly? I don't know how the device is built. The Flash could be internal to the processor.
A terrorist walks into a bar...
But seriously, folks...a terrorist walks into Kroger and buys bread. Can (not should) Kroger be prosecuted for supporting terrorism?
And - a known terrorist walks into Kroger and buys bread. Can (not should) Kroger be prosecuted for supporting terrorism?
ak
iPhone was not 'specifically designed' to aid criminal activity. It's a privacy/security 'tool'. Like any 'tool' it can be used for more than the intended purpose.The bread is not specifically designed to aid the criminal activity.
From a teardown:
Toshiba THGBX2G7B2JLA01 128 Gb (16 GB) NAND flash
Bob
The bread is food for the criminal. Without food the criminal could not proceed to do criminal like activities.
So, perhaps you need a fingerprint scanner in every grocery outlet to help ensure criminals don't have access to resources that allow them to continue their unjust actions.
This thread started as an inquiry as to why the FBI couldn't access the contents and has turned into a debate that is going nowhere.
What you are talking about Herschel is absolute transparency. It can't be obtained because of privacy related tech and code from Apple. You do realize that 'encryption' can be done with a pen and paper, or 3rd party apps on Android, iPhone, Windows Mobile, Linux, MacOS, etc... asking a company to make a back-door will not solve any problems and magically decrypt everything. People will simply stop using the product or start using other forms of protection.
