APC Back-Ups Office - Doesn't protect at all
  • Thread starter 00_DotNetWarrior
  • Start date
James Sweet
00_DotNetWarrior said:
Thanks a lot for all the comments, I think I will get a better one. I went
to tigerdirect, they carry APC Smart-UPS 1500 VA and they also carry
Cyberpower CPS1500AVR (1500 VA) Is this Cyberpower any good? It said it's
design for running server, it's like 30% less expensive than Smart-UPS...
any idea?
I've never heard of Cyberpower, but the name doesn't exactly reek of
quality. Personally I'd get an APC or a Tripp-Lite and not the cheapest
consumer grade one they make either, something mid-range intended for
office use.
I too have never heard of cyberpower.
For the most critical applications, ONEAC, for the not so critical
applications, APC (and not the cheapest line).
David Kuhajda
kony said:
Generally one does not want to "size" an ups to a system
like this, the UPS rating is a maximum, not a target.
The typical low-end system might be fine on a 500VA UPS but
with consumer grade UPS, it's $ well spent to go for at
least 700VA or more, especially if one is trying to power a
monitor too. Like anything else, run at UPS at it's max and
it may not last so long.
Actually this is exactly how a typical computer should be sized to the UPS.
As MOST computers only draw approximately 1/2 the power supply rating 90% of
the time, rating the UPS to backup JUST the computer (not the monitor also)
is correct and standard recommendation. If an individual has not checked
the typical current/wattage pull of their computer, and since very few
computers draw near the full rating of the power supply, the later
recommendation for typical home use still gives plenty of extra power
margin.
If longer run times are required, more than the expected 15-30 minutes, then
make sure the UPS will actually run longer when it is not under a larger
load. Most cheaper UPSs run x-minutes regardless of the load connected.
K
kony
the time,
There is no relevance to what % of the power supply is used.
The relevant parameters are amperage and uptime.
Again, no.
The UPS rating is a maximum. As with any supply (including
the system power supply) you saw it was rated for MORE than
the system used. Similarly the UPS should be rated for more
than the PSU uses. "Uses", not what it's rating is in
watts.
margin.
Mentioning the full rating of the power supply as a means to
pick the ups is simply invalid. It may be true that some
marketing departments do it merely because they know the
average consumer would not be expected to know the actual
current of their system. However, even these UPS tend to
have more than one outlet so it still can't apply.
Wrong, they run until the lower battery shutdown kicks in or
the temp rises too high (if thermally protected). Any UPS
that unnecessary shuts off after X # of minutes is a bad
design- though certainly their software might be set to shut
the system off after a period.
